Drives: ford focust ST
Is 12lb total difference in weight going to affect a lot?
So I am looking at some wheel that weights 20 lbs. This is my option 1.
My option 2 has 23 lbs, so total difference for a set of 4 would be 12 lbs. Will 12 lbs make a difference a lot? What's ideal wheel weight for BRZ? |
Maybe you can feel it but it won't change much. Lighter should be better but in tests I've seen, the difference was much smaller than I'd ever imagine. Probably don't want to go heavier than stock though.
Drive upgrades. Don't buy them.
Drives: 2015 FR-S
More is always better. More weight in the corners would give better rotational mass to keep the speed higher and stay that way for longer.
They should have come at least in at 25 lbs OEM but due to average fuel economy standard laws, they had to go lighter. |
Drives: 2015 FR-S
More cheese. More money. More rotating mass. End conversation
A.K.A. Starlord
Drives: 2015 Series.Blue
You aren't going to take a half second off of your 0-60 times with a lighter wheel, and you likely won't improve your lap times by much either unless you're already fairly experienced.
HOWEVER, even a complete n00b will notice a few pounds of difference in wheel weight at highway speeds. Spinning wheels generate a lot of rotational inertia. You know how the wheels on a bicycle keep you upright when you're moving? Or how a gyroscope can be balanced on your finger when it's spinning, and resists your attempts to knock it over? That's what your wheels are doing when they're spinning. Heavier wheels/tires exaggerate that force, which results in a heavier steering feel. I remember back when I was using cheap, heavy steelies for my winter tires, just how big of a difference it made. At higher than city speeds, it felt like the power steering was dying. It's not a HUGE difference, and it won't really affect anything in your DD, but it DOES detract from the "light and nimble" feel of the car when the steering gets harder to turn, as it feels like the car is less interested in darting back and forth.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
Only users lose drugs.
Drives: All the time
Will it make a difference? Of course. Will you be able to tell? I have no idea how sensitive your butt dyno is, but chances are, no.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#7 | |
Country Boy 4 Life
Ideal weight for what? The ideal weight for: Value = heavy Track = The lightest and strongest wheel DD = What ever you can justify/afford. I spent more on my tires than I did my wheels. $1000 > $700 They weigh approx. 20lbs each. They are a little heavier than stock, but look fantastic, are wider, and are 18's which have more tires available. I chose MPSS.
I LIKE TIRES! |
Drives: 2015 FR-S
I'm surprised people are playing along.
Drives: 2014 GT86
Stang70Fastback: THE biggest feel change with winter tires probably came from (possibly) their higher side profile and more then probably from much softer compound & sidewalls. Even on very same wheel most winter and all season tires will rob lot of steering sharpness.
Lighter wheels can be felt a bit and they can improve performance a bit .. but only slightly. In many cases below what they may cost. From another viewpoint though .. if one decides to change wheels anyway for looks reason, to add some individual touch, why not look for if new wheels will be lighter too to reasonable extent? (forged wheels, even while the lightest, rarely are worth their high price. But lighter cast wheels .. or used forged ones in good condition .. why not?) |
#10 | |
Drives: 2005 Toyota Camry
Tires make a bigger difference if you are nitpicking. |
#11 |
Good Samaritan Syndrome?
Haven't read all the other threads?
#12 |
The Fail Boat
Drives: CWP S.B.
Hey it's our new favorite person khcho19
![]() now i miss that dude who used to ask random questions that made you fall off your chair..........I just don't seem to remember his name >__> |
#13 |
Rice King
ludwigMUTHAFUCKINmiles
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#14 | ||
A.K.A. Starlord
However, that doesn't make the steering wheel harder to turn. In fact, it actually makes it easier to turn, as the forces being imparted back through the steering wheel build up more gradually (and also have far lower limits due to the lower lateral grip.) I'm referring to the steering effort required, not the actual response to a given degree of steering input. The steelies were heavy (IIRC, 25 lb vs my stock wheels, which are 18.4 lb - as I have a Series.Blue), and the overall difference in weight resulted in a very noticeable increase in the amount of steering effort required at higher speeds, due to the increased rotational inertia. Quote:
It's all about priorities. I was just answering his question about whether or not there was a noticeable difference
| How much does wheel weight affect performance? | Slammillionaire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 89 | 07-05-2019 02:20 PM |
| 3 pound weight difference? | UtahSleeper | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 07-05-2017 12:21 AM |
| FR-Sandwhich: Total or not total? | Joshwahhhs | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 10-03-2015 08:11 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
| weight difference between auto and manual??? | sofrsnsokleen | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-22-2012 11:40 PM |
