Old 07-02-2017, 12:03 AM   #1
UtahSleeper
UtahSleeper's Avatar
Drives: 80 Corolla 88 Celica Alltrac 13 FRS
3 pound weight difference?
So, I have narrowed my wheel search down to these 2 wheels. I would prefer them both with a little less offset, but can't find anything. With that, I have a question.
Rota Titans 17 pound
Konig Oversteer 20 pound
I would like to get the lighter wheels for function alone, but will I notice anything with a 3 pound drop per wheel? Butt dyno? Gas mileage? Anything?
Thanks for any feedback.
UtahSleeper is offline   Reply With Quote
Old 07-02-2017, 12:39 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Are you into time attack events? Do you need to save every single ounce in order to gain .03 seconds cause that's what makes or breaks a win or loss?
Or so you just use your car for normal daily/weekend fun use?
If you answer yes to the first get the lightest wheel. If you answered no, then flip a coin, or go on a diet. It's your call. The difference would be only felt on the butt dyno, maybe a hair of a difference in gas.
Old 07-02-2017, 01:10 AM   #3
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Take out your spare tires, you instantly get 23lb free up.
FR-Sky is offline   Reply With Quote
Old 07-02-2017, 08:41 AM   #4
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
it is 12 lbs total and will you notice it? Maybe a little, but remember tire weight is just as big a concern.
Old 07-02-2017, 09:23 AM   #5
Gforce
Drives: 2013 Subaru BRZ
Lighter wheels are always good if they are strong enough. Since almost all tires are heavier than the Primacy you should look for the lightest wheels you can afford that are strong enough. The total wheel tire weight is what counts as the previous post emphasizes. Stock wheel and tire weigh just overs 40 lbs. better performing tires in the same size are two to four pounds heavier than the Primacies. Wider tires are even heavier.
Unsprung weight affects the spring and damper effective rate in the same way as actually changing the spring rate, from a wheel control perspective, I.e, ride effects. Higher wheel weights require more spring and damper force than lower wheel weights. Grip over bumpy roads is improved with lower wheel weights.
Gforce is offline   Reply With Quote
Old 07-02-2017, 09:39 AM   #6
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
This right here. Tire weight is on the outside and harder to spin. With this car being low powered I believe you need every weight advantage especially rotating.
For the record both those wheels were very high on my search list.
Since you are looking at 17x8 sizes I went with the Konig Hypergram. Has little better offset +40 to push the wheel out a little more and weights ~16lbs. Also went with Hankook Evo2 tires in stock size that weight 19lbs. So I'm saving ~6lbs or rotating mass per wheel. I put these on along with a lighter pulleys and felt an immediate ease of acceleration.
SuperTom is offline   Reply With Quote
Old 07-02-2017, 06:17 PM   #7
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
For track use there is a measurable difference assuming the tires are the same for both and the lighter wheel is stiff/does not flex.
For street use the most important factor is probably actually braking distance... and a three pound per wheel difference might make the difference between avoiding a collision or not. Depending on tires, a three pound difference in rotating mass could be in the 5-10 ft range on a 60mph to zero stop.
nextcar is offline   Reply With Quote
Old 07-02-2017, 09:40 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I'm at ~36 pounds total with a 12.5 lb wheel and 23 lb tire (225/50-16), and while I can say I definitely feel a difference (mostly in suspension reaction/nimbleness), it's not something I'd call night and day. It doesn't 'transform' the car. But it does make it feel just that much more refined...any unspring and/or rotating mass lost is a good thing.
venturaII is offline   Reply With Quote
Old 07-02-2017, 09:52 PM   #9
Chronology
Drives: 13' Satin White Pearl BRZ
To further this example you get to a point where you pay 100s extra to save a few pounds of unsprung weight, this car being a momentum car you can really push it harder when off the public streets.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 07-03-2017, 08:05 AM   #10
Azzudien
Drives: 2017 Series Yellow BRZ
Just another option, that is lighter and similiar style
https://www.tirerack.com/wheels/Whee...=Series.Yellow
Azzudien is offline   Reply With Quote
Old 07-03-2017, 09:29 AM   #11
SuperTom
SuperTom's Avatar
So you added a heavier tire on the outside rotating mass probably why you didn't feel as much
Old 07-03-2017, 09:32 AM   #12
SuperTom
SuperTom's Avatar
Those are good and light but a little pricey. Heres another good bang for buck wheel that looks good 17lbs Advanti DST storm
https://www.tirerack.com/wheels/Whee...17&autoModClar=
Old 07-03-2017, 12:01 PM   #13
venturaII
venturaII's Avatar
Yeah, I realize that, but it's only a pound heavier than the OEM Turanzas and I'm still significantly lighter in all three areas (rotation, unsprung, and overall weight), and it's enough for me to feel, so I'm happy. And buying the wheels used made the whole setup a relative bargain.
Old 07-03-2017, 12:49 PM   #14
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I'd worry about wheel weight, but not tire weight AT ALL.
Wheel weight...lighter is better, but are you being paid to race? Do you really think wheels that weight 3 more pounds is really what's holding you back?
Tires...usually heavier tires have stiffer sidewalls. Buy the best damn rubber you can afford, for your application. Car see's lots of water? Don't buy summer only tires etc. Ideally, if you live in a place with seasons, two sets of wheels/tires is nice...
bra difference from frs shift2launch BRZ First-Gen (2012+) — General Topics 5 01-22-2015 01:00 AM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Shorai Lightweight Battery and #Lighterisbetter CNC Machined Tray - 6.75 pound setup KCMachine Groupbuys 73 02-27-2014 01:04 AM
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 09:32 PM
weight difference between auto and manual??? sofrsnsokleen Scion FR-S / Toyota 86 GT86 General Forum 1 08-22-2012 11:40 PM
