Old 05-01-2018, 03:08 AM   #1
congee
congee's Avatar
Drives: SSM BRZ
Cracking noise in reverse
Hello,
Recently experiencing an issue where I hear a loud cracking noise coming from the front passenger side whenever i'm reversing, wheels turned and applying a bit of brake. Every time i'm backing into a parking space I hear this constant cracking noise. What sounds like plastic snapping in half.
I thought it was maybe my wheels rubbing my wheel well liners or possibly my skid plates but after inspecting, there was no visible damage on either.
The weird thing is, if i'm driving forward, wheels turned and applying a bit of brake, there is no noise. Only when i'm in reverse and wheels turned is when I hear this noise.
Anyone have any clue what I can do before having my mechanic check it??
congee is offline   Reply With Quote
Old 05-01-2018, 08:59 AM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Does it happen only once when you apply the brake or every time you let off the brake and step on it again while backing in? Or, does it happen if you don't apply the brake?
shiumai is offline   Reply With Quote
Old 05-01-2018, 09:18 AM   #3
Is the car stock? Mods? Change anything recently?
Old 05-01-2018, 11:00 AM   #4
congee
congee's Avatar
Drives: SSM BRZ
Only happens when I touch the brakes. Even a slight touch and I'll hear it. If I reverse and turn without braking. No sounds at all.
Just on coils and 17x9 rpf1s. Only changes I did recently was rotating the rims and swapping out the hub rings on the rims. Everything else is stock including the brakes and toes etc
The Following User Says Thank You to congee For This Useful Post:
Tcoat (05-01-2018)
Old 05-01-2018, 11:05 AM   #5
Check your hub rings.
congee (05-01-2018)
Cracking Header djghez Engine, Exhaust, Transmission 15 09-16-2017 12:54 AM
Mysterious cracking noise? Rocketman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-11-2017 09:43 PM
Rubbing noise on cold start only in reverse? brsaresmgs Issues | Warranty | Recalls / TSB 2 01-18-2015 07:15 PM
Clicking noise when shifting from Park to Reverse -AT 01s0uljah Engine, Exhaust, Transmission 1 10-30-2014 06:39 PM
Loud noise and rattle in reverse BeRZed Issues | Warranty | Recalls / TSB 0 06-23-2014 09:38 PM
