22R
Drives: 2012 Camry SE 2017 Toyota 86
Gruppe S header install question
Hi guys,, I just bought a used Gruppe s ceramic coated header and will be installing with new OEM gaskets in a week or so. Question is do I need the reflective heat shield that goes on the oil pan ? Car is street driven only and not abused. I don't think I will get the oil too hot but will the header blister the paint on the oil pan ? If so I will get one. Any advice appreciated.
22R |
#2 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Although I think the Gruppe-S header is shaped slightly different than the Tomei UEL, it still comes pretty close to the oil pan and the thermostat housing. I'd say if you have it and are under there...put it on. I don't think minimizing heat transfer would be a bad thing.
Wes
Since it's ceramic coated, I'd say nah
Instagram: @gt86ws
22R
Thanks guys. I may just put a piece of insulation wrap on it where it passes near the pan with a SS band.
22R |
Drives: 2013 Scion FRS
I have a Gruppe-S with the heat shield (uncoated), and oil temps stay around 210 degrees F just driving normally. When I do spirited driving on backroads for a little bit though, it’s not hard for it to reach 240 degrees F
If you don’t drive hard too often I’d say you’d be fine without it, but the less heat the better. |
Drives: C5, GT-86, '24 Colorado TrailBoss
You don't have to use their insulated piece. You can buy a stick-on roll of the stuff for like $15 and have plenty left over. Its worth the piece of mind
#8 | |
Drives: 2015 FR-S
22R
#10 |
A little more expensive then I remembered but plenty to work with. Has a weave layer and a reflective layer
https://www.ebay.com/itm/Thermo-Tec-...item33e7f024a4
| Offical Gruppe-S UEL Header Install & Review Thread | continuecrushing | Engine, Exhaust, Transmission | 313 | 06-11-2023 03:54 PM |
| Gruppe-S Header | rtalich | Engine, Exhaust, Bolt-Ons | 5 | 01-21-2018 08:31 PM |
| Openflash header 2 install question. | SubieRumble | Engine, Exhaust, Transmission | 5 | 12-25-2016 10:34 PM |
| LF: Gruppe-S Header or FT86SF Catted UEL Header | b11lee | Canada Classifieds | 6 | 12-14-2016 04:03 PM |
| WTB: Gruppe-S UEL Header | ThornhillSubaruOwner | Canada Classifieds | 1 | 09-01-2016 11:16 PM |
