Old 04-26-2018, 07:44 AM   #1
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Can't always shift into 1st?
I've been having a problem over the last couple of weeks where when I'm at a stop I sometimes can't get into 1st. Every time this happens, if I go back down, and then try again, it always works (clutch down the entire time). Double clutching has no effect.
Is this likely a synchro issue? I'd be a bit surprised since I'm pretty gentle with 1st, meaning I never engage it unless I'm going 5MPH or less. It has 62K miles on it.
edit: Also forgot to mention that for the last 10K or so miles I've had an aftermarket ACT XT Clutch/Flywheel.
flashburn is offline   Reply With Quote
Old 04-26-2018, 09:21 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Was the engine/trans warmed up? People have complained about that in colder climates. Many have also switched trans and diff fluids; a quick search will give you better answers.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-26-2018, 09:22 AM   #3
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Yea happens to me sometimes. I have to go into 2nd then first.
PandaSPUR is offline   Reply With Quote
Old 04-26-2018, 10:51 AM   #4
flashburn
Yeah, it's happened both after long drives and at cold start. I'm in Florida, and it's been pretty hot lately (85F+).
Old 04-26-2018, 10:56 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
When was the last time you changed your trans fluid?
jasonojordan is offline   Reply With Quote
Old 04-26-2018, 11:26 AM   #6
flashburn
It was changed at 55K miles, which was also when the Clutch/FW was replaced.
Old 04-26-2018, 11:34 AM   #7
jasonojordan
OEM fluid or?
Old 04-26-2018, 12:33 PM   #8
flashburn
OEM fluid or?
Pretty sure it was Red Line.
Old 04-26-2018, 12:37 PM   #9
jasonojordan
What variant do you know? Just curious as I switched to redline mt-90 this spring and hope to see how it drives. I was running motul trans fluid and was not a fan of it at cold temps/start up temps for the very issue your dealing with now.
Old 04-26-2018, 12:49 PM   #10
flashburn
Not sure, but I doubt it's the same issue, as mine will happen at any temperature, it just isn't consistent.
Old 04-26-2018, 12:51 PM   #11
jasonojordan
OEM Shifter and knob?
Old 04-26-2018, 01:20 PM   #12
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I've noticed that if the RPMs are above a certain limit, it will not let you shift into 2nd or 1st. I always just thought of it as a safety mechanism. Its like it locks you out. "Access Denied...until you slow the fuck down". So I never downshift below 3rd when coming to a stop before a light, but I do only when I'm already going at a steady crawling pace around stores.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 04-26-2018, 01:22 PM   #13
flashburn
Originally Posted by Lakitu View Post
I've noticed that if the RPMs are above a certain limit, it will not let you shift into 2nd or 1st. I always just thought of it as a safety mechanism. So I never downshift below 3rd when coming to a stop before a light, but I do only when I'm already going at a steady crawling pace around stores.
Makes no sense, I've never noticed that.
At 62K miles, this is a new occurrence, and definitely isn't something I would consider normal.
Old 04-26-2018, 02:07 PM   #14
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
you're a noob, you need more clutch & rev matching practice.. Rev matching into 1st is admittedly tricky considering how much work the synchros have to do but it is not necessary. If you are still rolling over 5 MPH just go into 2nd..if you are struggling with downshifting into 2nd, then ya need a mentor.
As for OP it is tough to diagnose these hard shifting problems over text and a video probably wouldn't really help either..best to get a buddy who is experienced with MTs and have him feel it. Dealership could help if ya don't know anyone..
HKz is offline   Reply With Quote
Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit zohaib Transmission and Driveline 5 03-08-2017 11:51 PM
SOLD: Whiteline Positive Shift Kit Bushing, Moddiction Shift Knob immaculate Transmission and Driveline 4 12-30-2016 06:52 PM
Auto to manual shift bezel (shift boot) oh96s Scion FR-S / Toyota 86 GT86 General Forum 10 05-23-2016 02:24 PM
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 09:33 PM
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 09:36 PM
