Old 04-23-2018, 05:47 PM   #1
robzz
Drives: Brz
Knock on throttle let off
Hi all, long time reader, few times poster here.
I've search quite a bit but found almost no thread about knock on letting gas off. A lot on tip-in knock, but few on the other way.
I see IAM getting adjusted down because of knock (FLKC) reoccuring. However, from what I can see, it's mostly when I let off the throttle. I see some minor knock on hard pulls, but IAM is never adjusted down soon after.
It also appears when I give less throttle. Let say from 10% to 50% and back to 10%. And mostly at low to moderate RPM (2500 - 4000).
Mods are a Gruppe-S UEL catless header, mishimoto intake tube, Perrin panel filter, invidia q300 and an OFT.
I've seen the phenomenon on V2.76 tunes, V2 OFH optimized, and V4.
Here are 3 datalog I think represent the issue. The IAM is'nt changed on those exemples, but the phenomenon is represented.
Any input will be appreciated!
https://datazap.me/u/robzz/10-v2-26?...zoom=8320-8402
https://datazap.me/u/robzz/09-v2-25?...zoom=3605-3870
robzz is offline   Reply With Quote
Old 04-23-2018, 06:51 PM   #2
steve99
make sure you don't have ant exhaust components like over pipe hitting on chassis as this can cause false knock indications.
your ltft seem quite high at +10 % check for exhaust leaks
do you have stock intake ??
Old 04-23-2018, 07:38 PM   #3
robzz
Drives: Brz
Thanks for the reply!
I'll have a look for bruises on over-pipe. From memory, it did'nt looked near anything but I'll check anyways.
For LTFT, I know they are high, particularly at idle. I "MAF scaled" it when it was a little cold outside (50°F) and those last log were taken near 75-80°F. Spring finally arrived!
I have a sorta stock intake. I have a Mishimoto Intake Tube with a Perrin panel filter. I'm pretty sure I have no leaks on the tube.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 04:12 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
