Old 04-23-2018, 02:54 PM   #1
Mikes33
Drives: FRS 10
FRS 10
How do you turn on the FRS 10 display on for the dash?
Mikes33 is offline   Reply With Quote
Old 04-23-2018, 03:23 PM   #2
mazeroni
Drives: 2013 Scion FR-S Series 10
FRS 10?
Do you mean the Series 10?
Do you also mean the passenger side "carbon" dash panel with the electroluminescent display that reads Scion Series 10, or whatever it is...
If yes, there is a toggle switch on the passenger side under the dash. http://www.ft86club.com/forums/showthread.php?t=99469
mazeroni is offline   Reply With Quote
The Following User Says Thank You to mazeroni For This Useful Post:
Tcoat (04-23-2018)
Old 04-23-2018, 05:16 PM   #3
Ciriously
Drives: FR-S 10 Series
I've actually been wondering.. How do I fix mine? It doesn't turn on even after toggling the switch.
Sent from my SM-G950U using Tapatalk
Ciriously is offline   Reply With Quote
Old 04-23-2018, 07:08 PM   #4
humfrz
Check the fuse ......??
humfrz
Old 04-23-2018, 10:02 PM   #5
Decep
Drives: 2013 FR-S Series 10
i been thinking about ripping mine out and replacing it with that newer style black/red dash. it looks pretty cheesy
Old 04-25-2018, 01:35 PM   #6
Cheeky
Drives: 10 Series FRS
I thought it was cheesy too... but I have gotten a lot of Ouu's and Woah's from my passengers.
Cheeky is offline   Reply With Quote
The Following User Says Thank You to Cheeky For This Useful Post:
dnieves (07-08-2020)
Old 04-25-2018, 03:33 PM   #7
mazeroni
Are you sure its not working? In my experience it has to be pitch black to see it.
Not sure your experience or knowledge about it.
It only lights up when you are stopped and open the doors. Once you start moving it should turn off. Or it will cut off after about 30 seconds if you don't move. Same as the badges.
Even then, it's not worth fixing if it's broken. It's super gimmicky. You won't even notice it most of the time, except if a passenger points it out. There are so many better looking trim pieces out there. I'd go that route or just leave it dead. I can't image what Toyota would charge.
bcj (04-25-2018)
Old 04-26-2018, 12:52 PM   #8
Ciriously
Hmm I'm not sure if it was pitch black. I'll have to try that.
You're so right though. No use is paying a premium to get it repaired. (I am a sucker for things that light up though)
The Following User Says Thank You to Ciriously For This Useful Post:
JesseG (07-07-2020)
Old 04-26-2018, 04:32 PM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Am i the only one that disconnected the badge lighting and dashboard light the first day of pickup?
Old 04-26-2018, 06:16 PM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
How do you disable the badge lighting?
N1rve
Old 04-26-2018, 07:18 PM   #11
NyC Zn6
NyC Zn6's Avatar
You unplug them. The rear badge can be unplugged in the inner section of the trunk lid. The front badge can be unplugged by the hood latch area up front.
Old 04-26-2018, 07:56 PM   #12
N1rve
N1rve's Avatar
Could you perhaps snap a picture ?
N1rve
Old 04-26-2018, 09:03 PM   #13
Decep
i think there is a button under the dash, no?
Old 04-26-2018, 10:19 PM   #14
NyC Zn6
NyC Zn6's Avatar
The button under the dash only controls the dash panel light. The badges must be unplugged to disable lighting.
