Old 04-21-2018, 12:16 AM   #1
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Strange thud noise from transmission when downshifting
I’ve only had this happen to me maybe three times since installing my short shifter/changing my transmission fluid back in February, and I’m not sure what’s causing it. Basically, when rev matching down from 4th to 3rd or from 3rd to 2nd, as I shift down gear to gear there is a quite audible thud or thunk sound that sounds like it’s coming from the transmission tunnel. Has anyone else had the same issue?
Some background:
My local shop when swapping out my transmission fluid back in February swapped my factory fill for Motul Competition 75W-140 GL5. I’m planning for my next oil change within the next couple of weeks and will ask them to swap the competition for Gear 300 GL4 in the proper viscosity of 75w-90, as I cannot confirm whether the different fluid is harmful or not... he recommended it to me as he runs it in all their Subaru’s, and me not doing my research beforehand I accepted. However, I don’t think the fluid would be the root cause of this.
As for the short shifter, the FT86SF short shifter has its own host of issues, most notably rattle and a reverse lockout which can’t hold the shift boot properly. Unluckily for me, I cant return it, so I have to wait for a fix from FT86SF. Could the shifter cause the weird thud?
Thanks!
JBezugs is offline   Reply With Quote
Old 04-21-2018, 12:54 AM   #2
humfrz
Some background:
Thanks!
I'd suggest that you wait till you change the oil back to the recommended type of oil and ask them to check the short shifter linkage at the same time.
humfrz
Old 04-21-2018, 01:15 AM   #3
Grey86
Grey86's Avatar
Drives: Tornato grey 86
Some background:
Thanks!
did you run the short shifter while on the factory fluids ?
i do wonder if the fluids are a bit low when it got changed over.
or the short shifter link is offset.
Grey86 is offline   Reply With Quote
Old 04-25-2018, 04:37 PM   #4
JBezugs
Good Job Subaru!
JBezugs's Avatar
I ran the new fill with the factory shifter for a month or so, had no such issues (at least I don't think so anyways...); could be the short shifter causing the issues, but I will be swapping the fluid anyways as I'm not comfortable with the "incorrect" fluid in the car currently.
2013 FRS A/T - Strange Noise jkost Issues | Warranty | Recalls / TSB 4 06-09-2017 12:46 AM
Strange noise Tiliziano Issues | Warranty | Recalls / TSB 1 06-05-2015 04:20 PM
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
New strange noise? kALMIGHTY Issues | Warranty | Recalls / TSB 45 05-02-2014 01:52 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
