Old 04-19-2018, 01:09 PM   #1
DeltaEcho
DeltaEcho's Avatar
Drives: 17BRZ Limited TS
OFT Crawford Blocks FLKC
Hi there,
I am currently running Works Drop-In Filter, Perrin Inlet Tube, PLM UEL Headers on this setup when I installed the power blocks. Using OFT Stage 2+ v4.02
After solid pulls on 3rd and 4th Gear.. I get some knock around the 6000+ rpm ranges. Could someone please take a look and make suggestions so I can adjust.
Here is the current layout on my OFT:
Knock Correction Max A:
https://drive.google.com/open?id=1W6...n6OXBMTZZx8ysn
Timing Compensation A&B
https://drive.google.com/open?id=15J...W10pczwVwyTokL
Data Log:
https://datazap.me/u/mpare024/crawfo...og=0&data=1-11
Additionally:
In about a week I have a grams throttle body and Perrin Cold Air intake (2.75) will be installing. I have the MAF curves and will use the Perrin Settings. Will the Throttle body increase FLKC and have to adjust again?
I will take data pulls once installed
Last edited by DeltaEcho; 04-19-2018 at 01:14 PM. Reason: Added graphics/info with working Links
DeltaEcho is offline   Reply With Quote
Old 04-19-2018, 02:21 PM   #2
bfrank1972
Drives: 2013 FR-S Argento
You see this thread?
http://www.ft86club.com/forums/showthread.php?t=71285
bfrank1972 is offline   Reply With Quote
Old 04-19-2018, 02:45 PM   #3
DeltaEcho
DeltaEcho's Avatar
Originally Posted by bfrank1972 View Post
Yes and the information is seriously dated; 2014...
OFT went through multiple maps over the past 4 years.
This is why this is a separate post.
Old 04-19-2018, 02:55 PM   #4
Teseo
Drives: frs
Wish op got a dynos before and after power block
Teseo is online now   Reply With Quote
Old 04-19-2018, 05:08 PM   #5
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I can see that your car is pulling timing, but there is not enough additional data to determine why it is pulling timing.
What is your Advance Multiplier? Given you're seeing positive FLKC, that usually means the Advance Multiplier is less than 1, which then also means it's pulling timing in other areas that are not in this log.
What I can see is that in the areas you're pulling timing, fueling is a bit lean at 12.5-12.8 or so. At 6,000+ RPM, making things a bit richer here can help quite a bit with taming this timing correction. I'd try richening it up to between 11.8 and 12.3 in this area, and seeing if that helps. If it still corrects the same amount, pull the appropriate amount of timing out of your Knock Correction Advance Max maps.
-Zach
Old 04-19-2018, 09:35 PM   #6
steve99
As avove it looks lean likely causing knock
Good set of parameters to log is
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
Ignition Advance / Total Timing (degrees)
AFR
Commanded AFR / Target AFR
STFT (percent)
LTFT (percent)
Oil Temp (F)
CL/OL / Fuel Sys Status (2 = CL, 4 = OL)
IAT / Intake Air Temp (F)
IAM / Ignition Advance Multiplier
FLKC / Fine Learning Knock Correction (degrees)
Its also a little strange your ltft is always zero , was this log done imediatly after flash ? Or have you disabled ltft
What are your end goals ?
The three mods you mention
Craford blocks
Intake
Throttle body
Wont trealy help you much but will cost you a lot
NA you wsnt a good catless header and exhaust
Tune
Or tunefor e85 fuel or flex tune will be best bang for buck
Craford block work on stock cars but on runed cars you can get similar results with cam riming adjustments
Throttle body not rearly needed stock one flows well
Same with intakes very minimal gains
The supploed perrin scaling is not that great and will usually require further adjustment
Old 04-19-2018, 10:08 PM   #7
DeltaEcho
DeltaEcho's Avatar
Followed the build, flashed it, will post data later in the week...
It is just one of my Daily Drivers. I just drive it for fun and do some mods to it to have fun from time to time. Not going on the track.
e85 and Crawford power blocks Lantana frs Engine, Exhaust, Transmission 10 07-21-2018 11:34 AM
Crawford power blocks Lantana frs Software Tuning 2 10-11-2016 09:54 PM
Crawford Blocks and AOS need gone Opsfrs Engine, Exhaust, Bolt-Ons 6 04-26-2015 10:26 PM
Crawford power blocks fs Triumphrider Engine, Exhaust, Bolt-Ons 2 04-06-2015 11:17 AM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 09:22 AM
