Old 08-01-2014, 06:20 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes
Hi guys,
As promised, here is a tutorial on how to adjust any of our gasoline OTS map (91 or 93) to work well with the Crawford Power Block. Of course, additional dataloging/testing is always a good idea. But the changes outlined below are easy to implement and will work well once you add BPBs.
Note: This tutorial is only intended for our gasoline OTS maps. I never had too much success with running the BPB on E85.
Using Rom Raider, open up your current OTS map (Stage 1, Stage 2, Stage 2 UEL or Stage 2 EL) view the following tables:
Knock Correction Max Advance A
Timing Compensation Per Cylinder A
It will look like this:
Step One:
Set both Timing Compensation Per Cylinder tables to 0.
Step Two:
In the Knock Correction Max Advance A table, copy the entire 6000RPM row and past it in the next 5 rows (6400, 6800, 7000, 7200 and 7400).
Once you are done, the tables should now look like this:
Step 3: Close the windows. Save the file under another name (i.e., Stage 1 BPB A01C).
Step 4: Close and re-open the file.
Step 5: View the three tables you changed and confirm that they changes are there and exactly as shown above.
[Steps 3-5 are just for the sake of safety]
Step 6: Load up the revised BPB map into your OFT and flash to your car. As always, let the engine idle for a minute after first start-up before driving off. Go ahead and run the car. You will feel some good power gains above 6200rpm. Along with the good power gains that the BPB provided between 5200-6200rpm.
Step 7: Take some datalogs of 3rd gear WOT runs (2000-7500rpm) and confirm that there is little to no knock correction. Especially above 6000rpm where you made the adjustments.
That's it!
Cheers,
Shiv
Old 08-01-2014, 10:35 PM   #2
Namuna
Namuna's Avatar
Just ordered my OFT today and have had the BPB for a few weeks now.
Totally stoked!!
Namuna is offline   Reply With Quote
Old 08-02-2014, 04:10 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Shiv, what's the reason for adjusting the rear cylinder compensations for this and not for the other tunes? Which I guess asks the question as to why they are there in the 1st place?
I know that zeroing out the compensation is a good way to make power but at what cost?
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-02-2014, 10:45 AM   #4
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
i'm trying to update it in romraider, but i'm unable to open the tune.
it always say "Unable to read XML definition. Please make sure the definition file is correct. If it is in a ZIP archive, unzip the file and try again"
wich I did. I put your new XML, selected it, and can't open the tune. (note that i was able to do it with previous tune)
Walla Walla is offline   Reply With Quote
Old 08-02-2014, 10:58 AM   #5
Malt
Drives: 2015 WRX
Are you using the XML from the 2.0 or the 2.01 map file? You should be using the one in the 2.01 zip. Did you remove the old definition from the list of XML's in romraider and then add the new one? Several people forgot to do that.
Baring those solutions maybe you could try and re-download the 2.01 zip and try it all again. Maybe something got messed up inadvertently.
Malt is offline   Reply With Quote
Old 08-02-2014, 11:49 AM   #6
Walla Walla
Hicas Thread Basher
i'm using the 2.01 one (never had the 2.0 since there was no solution at that time for BPB) and i've removed the older XML.
i've unziped it twice, but didn't try to redownload it... i will try right away.
i've also double check with the old XML and an old tune to be sure romraider was ok, and it's was working.
Old 08-02-2014, 11:57 AM   #7
Walla Walla
Hicas Thread Basher
it worked.....
redownloaded the zip, extracted it again..... paste it over the folder where i've transfered tunes and xml first, found out that files were duplicated all over with same name....? to realise that the first time, i took the xml and tunes from Mac osx... on my pc....
i know... now i doubt of my intellectual capacity to edit those roms......
Old 08-02-2014, 12:44 PM   #8
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
made the changes, uploading now!!
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-02-2014, 04:18 PM   #9
Silver Ignition
APEXHNTR
here's a 3rd gear WOT pull I did...any feedback?
#1867 of 2500
Old 08-02-2014, 04:24 PM   #10
Malt
Drives: 2015 WRX
Upload that to datazap, much easier for everyone to give you feedback
Sent from my SCH-R970C using Tapatalk
Old 08-02-2014, 05:36 PM   #11
v86
Kid Gt86
v86's Avatar
Drives: SRT / Pulley / Tuned / Drop in
Fixed
http://imgur.com/cdQ01d9
v86 is offline   Reply With Quote
Old 08-02-2014, 05:39 PM   #12
Walla Walla
Hicas Thread Basher
I flashed, waited on idle for a few minutes and now I'm not at home but I've looked on the tablet for a few minutes on the highway and I've noticed my advance multiplier fell from 1 to .88 and then at each 5 min it raised to .91, .93 and. 96
Is it normal at the beginning ? Should I worry ? I will post logs once I'm home
Old 08-02-2014, 10:45 PM   #13
Silver Ignition
APEXHNTR
thanks! still new at this…
http://www.datazap.me/u/silver-ignit...1?log=0&data=1
@Shiv@Openflash
#1867 of 2500
Old 08-02-2014, 11:32 PM   #14
Malt
Drives: 2015 WRX
How many miles are on this reflash? Your IAM is at 1 but you didn't log FLKC or FBKC so its hard to tell exactly whats going on. Based on the dropping of chunks of KC learned through your pull I'd venture to say you've got some knocking going on but if this is a very recent flash your ECU might not of had enough time to adjust the trims.
Log again but this time uncheck VVT Intake and VVT Exhaust and select Knock Correction and FLKC and do another log for conformation.
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
