Old 04-11-2018, 12:27 PM   #1
Ornelas66
Drives: 2015 Scion FRS
Suggestions on tire size for a stock 2015 FRS
I am looking at changing the original tires on my stock FRS. It has stock suspension and stock rims. I was thinking about going with Michelin Super Sports or Michelin Super Sport 4S. I live in South Texas (Extreme Heat).
Also, I was thinking about going up in size from the 215/45R17's to 245/40R17, or should I consider 245/45r17's. My thoughts are that the 245/40r17 will have better grip on the road. This care is a daily driver.
ANY and ALL suggestions or thoughts are appreciated.
Ornelas66 is offline   Reply With Quote
Old 04-11-2018, 12:34 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
245 are going to be a stretch for the stock wheels. Stock wheels would be better suited to a 235 in my opinion. That said what are the main things you do with the car.
jasonojordan is offline   Reply With Quote
Old 04-11-2018, 01:09 PM   #3
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
if it is a daily there is absolutely no reason to go up in size, tire compound is what gives you traction. The infinitesimal amount of grip you will gain by having a wider tire is not worth it outside of timed events.
Stick with a 205 or 215 sized tire for dding. Only if you are thinking of competing do you need to go wider, and 245 really should be on a 9 inch wide wheel.
Old 04-11-2018, 01:10 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I wouldn't go any wider than 225 on the stock 7" wheels, and 215 is a better fit on them.
Stock wheels, I'd stick with 215. If you want wider tires, you should get wider wheels. 8.5" to 9" for 245/40-17s.
Wider tires aren't going to give you that much more in terms of grip on the street anyway.
Old 04-11-2018, 04:05 PM   #5
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I may live about 70 miles south of you. My plan is to stick with 215s. IMO the only things 235s or wider will buy on stock car with the stock wheels are a pinched contact patch, heavier steering, lower mpg, and a lighter wallet.
Oh yeah. The look. But I'm 64, I haven't picked up chics with a car in 40 years and I don't get the impression the twins are chic bait even if that was the plan.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-11-2018, 04:18 PM   #6
JMon85
JMon85's Avatar
Drives: 2019 WRX
JMon85 is offline   Reply With Quote
Old 04-11-2018, 04:23 PM   #7
Jordanwolf
Rice King
Jordanwolf's Avatar
Dude.. You'd be surprised. The amount of "chic's" that have looked at this car and were like: wtf, so nice, w0w, want touch, is porsche? Is surprising. It also helps to live in an area where every second car isn't a M series, AMG, or any other supercar/super luxury car under the moon.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 04-11-2018, 04:49 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You don't need better grip for a daily, and compound has more to do with it then width. Primacies actually aren't bad, but there are plenty of UHP summer tires that you'll be happy with in stock size. Also note the wider and stickier your set-up is your MPG will drop a little.
215 or 225 MPSS/MPS4S is more then fine
Best Tire Size for Stock Rims djliquidsteele Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 09-03-2017 02:10 AM
Largest tire size on stock rims? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-20-2015 11:05 PM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
Best performance tire size for stock wheels? Tenchi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-30-2014 06:06 PM
Optimal Tire Size For Stock Rims Raven604 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-05-2013 08:41 PM
