Old 06-30-2013, 10:19 AM   #1
love 4 boost
love 4 boost's Avatar
Drives: Raven black FR-S
Fuel cut or bad ecu signal?
My frs has about 8000 miles on it and I just had the fuel pump changed to get get rid of those nasty crickets for a bit, this is not even a week later and last night after I got back from club loose I decided to have some fun at my secret spot. Not even 10 secs into drifting car lost power and gripped up and while I was slowing down it completely stalled. Few cranks and got nothing and have it the oh shit car is going to leave me stranded again. Turned the key completely off and cranked it and luckily it started but the idle was dipping, I pulled away and the car kept puttering in every gear for about 2 mins.
Not sure if anyone else has seen this issue but I figured maybe fuel cut if the fuel pump was installed wrong, maybe just a bad signal from the ecu, or oil temps were high from hour ride and the drifting put the temp to a point of going into limp mode.
Please anyone chime in if they have an idea because I am in no way ready to start with bs this early on.
love 4 boost is offline   Reply With Quote
Old 06-30-2013, 10:28 AM   #2
charged86
charged86's Avatar
How much fuel was in your tank. Doing donuts with not enough fuel could starve the fuel sender.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-30-2013, 10:38 AM   #3
love 4 boost
Little over a quater
Old 06-30-2013, 10:57 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
i had fuel cut issues before from a bad EDU connection
any CEL codes??
86_ZN6 is offline   Reply With Quote
Old 07-02-2013, 01:16 PM   #5
love 4 boost
any CEL codes??
I had 1 last week when my car wouldn't start saying low pressure in the fuel rail, I had brought it to Toyota and they couldn't find the issue and just replaced the fuel pump to get rid of my crickets
Old 07-02-2013, 01:57 PM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Whats the code?
Old 07-02-2013, 02:04 PM   #7
charged86
charged86's Avatar
These cars do have fuel starvation issue below half tank but that only was the rule for boosted cars. The fuel pick up is on driver side. In the middle of tank is a large hump
Old 07-02-2013, 02:04 PM   #8
mad_sb
Drives: 2013 Asphalt FR-S
were you low on fuel then that code popped up?
1/4 tank I would say you were just too low on fuel to be slinging the ass around and starved the pump.. The ecu will act up if you spin the car even in asc off mode (not the pedal dance, but can still go into ice mode even with the pedal dance)...
However, the fact that you got a low rail pressure code a week before this.... that is a little suspicious and seem too much of a coincidence to me.
Old 07-02-2013, 03:20 PM   #9
love 4 boost
So as long as I keep the fuel above a half tank I shouldn't have this problem again?
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
MAF signal sw20kosh Engine, Exhaust, Transmission 1 05-31-2013 12:35 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
