Old 04-10-2018, 02:09 AM   #1
Augora
RE-71R - Quieter alternatives?
Love the traction I got from my last set of RE71's but would trade in some of that for a quieter ride on my DD. Are there any other obvious options for a quieter ride on the stock rims? Wouldn't mind a little more comfort either.
Willing to give up a fair amount of traction as I'm planning to buy separate wheels/tires just for AutoX, but would like my DD tires to at least hold me over for a few fun events until that happens.
Augora is offline   Reply With Quote
Old 04-10-2018, 02:41 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I'd try MPS4 / MPS4S. Should wear better/be quieter/have good wet grip. Imho all qualities that matter in DD.
Old 04-10-2018, 08:38 AM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If you're going to have two sets of tires, you might also consider the Continental Extreme Contact Sport. It's 95% of the tire the Michelin is, but being far less expensive, it'd leave you with more budget for autox tires.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 04-10-2018, 08:58 AM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
You won't find a tire in the same performance bracket as the RE71R that's 'nice' on the street.
Your best bet is to run dedicated autox wheels and tires. I'm a huge fan of S-04's and MPSS as a street tire, and RE71R's for 'kill mode'.
If you're having traction issues with that class of tire, you need to confirm if you have a street car, or not. :P
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 04-10-2018, 11:37 AM   #5
strat61caster
strat61caster's Avatar
https://www.tirerack.com/tires/surve...ay.jsp?type=EP
idk maybe RE11 or Falken's?
Most people are suggesting Max Performance tires which should be more than enough grip for street and casual autox/hpde, it's why I bought MPSS which are decent and my next set of DD tires will be of a similar category ~300TW MP or I've heard good things about the Firestone Indy 500's
https://www.tirerack.com/tires/surve...ay.jsp?type=MP
ineedyourdiddly
Old 04-10-2018, 11:49 AM   #6
CatDaddysBBQ
Drives: '13 FR-S
None of the tires in that class are quiet, it's just something you live with if you want that level of grip. Nothing in the next class down can touch the re71 in that respect, so you choose whether you want something streetable and 'decent' at autoX or track like a PSS or something, or if you want as much grip as possible.
You can't really have both.
CatDaddysBBQ is offline   Reply With Quote
Old 04-10-2018, 11:58 AM   #7
venturaII
venturaII's Avatar
Just to reiterate - OP says he plans to run 2 SETS of tires - one for autox, and one for street. The suggestions above for street tires are based on this, and I assume OP plans to continue running RE-71R for autox.
Old 04-10-2018, 12:16 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm pretty much in the same boat. I have a track set and a street set. For the first time in my life (I'm 42), I've intentionally chosen to prioritize comfort (noise and feel) in street tires with this car. I still have high performance summer tires, but nothing like RE71s. I don't measure the time it takes to go from home to the gym in hundreths of a second, so I'm OK giving up a little performance. Especially knowing I'll save money and be more comfortable at the same time, while still having a lot of fun.
Regardless, there's a lot of good info in this thread already. In short, I wouldn't bother with anything in the same class as the RE71s for the street.
Old 04-10-2018, 12:37 PM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
For what it's worth, my Maxxis Victra VR-1 autocross tires are way quieter than my daily pilot super sports.
I used to have Hankook Ventus V12 that were pretty quiet.
BigTuna is offline   Reply With Quote
Old 04-10-2018, 12:41 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Bridgestone S-04 for DD. Awesome response and pretty good grip for a non 200TW tire
Old 04-10-2018, 03:50 PM   #11
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
Wierd I run re71r on my Supra and I thought they were really quiet. Maybe it gets worse as they wear?
Silvermk2 is offline   Reply With Quote
Old 04-10-2018, 03:59 PM   #12
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
RS4 Hankook
Kayysonie is offline   Reply With Quote
Old 04-10-2018, 04:02 PM   #13
Jordanwolf
Rice King
Jordanwolf's Avatar
Off topic, but related to RE-71R... Are these things cheap everywhere? Because I can get these at $140ish CAD per tire, in stock size, where everything else is almost $200 per..
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 04-10-2018, 04:12 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
Now calculate in price how many sets of RE71R you'll wear down per set of tires of more reasonable threadwear for same mileage ..
Are the 2017's quieter than the older ones? TheCanadian BRZ First-Gen (2012+) — General Topics 23 09-28-2017 03:28 AM
Anything quieter than Q300 besides stock? gotbeef Engine, Exhaust, Transmission 20 03-24-2017 08:59 PM
Quieter crickets Jajanken86 Northwest 6 10-10-2016 01:18 PM
which front pipe will quieter? help Visitor.S Engine, Exhaust, Transmission 3 07-25-2016 09:49 AM
trade N1 catback for something quieter cdq85 NY / NJ / CT / PA 2 06-13-2015 11:45 AM
