CANADA Canada
Old 04-09-2018, 04:43 PM   #1
Cookies
Drives: 2014 FRS Black
Gas Mileage
I bought my car about 5 or 6 months ago and have been noticing that I have only been getting 240-300km to a tank, all city driving pretty much under 80 kph 90% of the time. Doing all highway i could manage 400km to a tank
This seems pretty bad, but i blew it off dismissing it as me being new to manual and the amount of city driving i do. I have tried to keep the rev's pretty low and still only hit the higher end of that range. (Car was originally from Alberta)
I have replaced all the spark plugs and flushed the engine for carbon build up, still no difference. I am also running new tires.
My question, is this km bad considering its all city driving, and if it is what should i look to improve it?
Cookies is offline   Reply With Quote
Old 04-09-2018, 04:49 PM   #2
StraightOuttaCanadaEh
Wes
That's bad. Even during winter, with the MY17's shorter gearing, I get about 420 km from full tank to fuel light. I reckon something is off. What kind of gas do you use?
Instagram: @gt86ws
Old 04-09-2018, 05:34 PM   #3
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
You'll need to provide way more details on your daily driving. Is it all free flowing highway driving or all city? I review cars on the side and I've blown through MPG estimates thanks to my heavy city commuting but once I get on the highway with free flowing traffic and I come back down to specifications.
Also, are you sure you're not lugging the engine? Switching to the highest gear possible can work against you in certain conditions.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 04-09-2018, 05:42 PM   #4
Jordanwolf
Rice King
Jordanwolf's Avatar
Idunno, I easily get 500 km per tank on larger diameter winter tires, and primarily city driving.
This seems really really bad to me.
Only reason I could see such bad KM would be from using gas that has like 35% ethanol or something.. Try 91 shell if you aren't already.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 04-09-2018, 05:49 PM   #5
Cole
Not a troll
Cole's Avatar
My gas mileage went down to 325km ish per tank this past winter. Likely due to a bad o2 sensor, then took a while to improve again once that 02 sensor was replaced. My mileage is hurt anyhow, since I have fender spoilers, plus a wing. But now it's improved to 400ish km.
FWIW, most of my driving is city driving with only brief stints on the highway. Though I did get 600km on a tank a couple weekends ago when I drove up to the bruce peninsula.
Are you throwing any codes? Rough idle? Aero? etc?
Old 04-09-2018, 05:51 PM   #6
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
that does seem off, try changing up your driving style for a week and see if that makes any impact +/-.
I don't daily mine often but even with "spirited driving" have been seeing ore than 300 to a tank.
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
Old 04-09-2018, 06:02 PM   #7
Cookies
I run the highest gas I can find at each station, I usually fill up with Esso so I think it's 91 or 93. I have no codes up on the dash currently and the car is stock aero wise.
Usually city driving around 60 kph or so with stop and go traffic 1/4 of the time or so. The idle is about 600 or 700 after warmed up, but about 1.5k on startup for about 15 seconds which I hear is a regular frs thing. I avoid that lugging sound when I shift to too low rpms
When I try to hyper mile the car I can manage barely over 300 maybe like 320, but on the opposite end I have had 240 km tanks from driving hard.
Think that covers everything?
Old 04-09-2018, 08:16 PM   #8
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
A Canadian thread about gas mileage with no L/100km.
wutsaiu is offline   Reply With Quote
Old 04-09-2018, 08:18 PM   #9
Jordanwolf
Rice King
Jordanwolf's Avatar
You can calculate L/100km based off of people saying what they are getting from a full tank. It wouldn't be accurate to the decimal, but it gives an idea.
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
wutsaiu (04-10-2018)
Old 04-09-2018, 08:42 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Do you have a way to datalog? A bad o2 sensor can kill mpg (I'v already had to replace mine).
Also, do you aftermarket wheels/tires? Power mods?
Old 04-09-2018, 08:52 PM   #11
Frost
Frost's Avatar
This.
Any mods? Cold weather this winter also made fuel economy as bad as almost 10-15% worse.
Old 04-09-2018, 08:58 PM   #12
Cookies
Car is stock in the engine bay, I had the stock rims and tires on during the summer till about two days ago. No difference with the winters or the new rubber that I can see so far.
Old 04-09-2018, 09:04 PM   #13
Frost
Frost's Avatar
Winter tires AND low temperatures affect the fuel econ.
Have you noticed you running rich on startup?
Old 04-09-2018, 09:09 PM   #14
Cookies
I have noticed the car is a bit jerky when starting in the cold. It will lurch forward a few times when pull out of driveway in first gear.
I had driven my car all last summer with slightly better fuel economy, 280-320km a tank.
What's your mileage? Aussie Jase Scion FR-S / Toyota 86 GT86 General Forum 54 08-16-2020 08:10 PM
Gas mileage??? thecarfilmer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-22-2015 08:13 AM
Most mileage while FI Triumphrider Forced Induction 14 09-15-2014 08:27 AM
Gas Mileage frosty86 Hawaii 12 10-09-2012 04:56 AM
How much mileage do you have on your car now? iff2mastamatt Other Vehicles & General Automotive Discussions 82 01-11-2012 01:48 AM
