Drives: toyota 86 2017
New to this car-have several question
At certain speeds, there's panels or something behind the dash of my 2017 86 that start to oscillate/buzz. All I have to do is change my speed a little and it stops. Is this something the dealership can fix, or is this something that is normal for this car. I've only got about 500 miles on it so far. Certain frequencies from the stereo will also start to make the same thing start buzzing.
2nd question. My torque coolant temp at idle in a parking lot is 200F/93C. Is this normal or should it be running cooler? 3rd question. My wife also owns a Subaru forester xt with cvt tranny. She has Hill assist. I have an auto tranny on my 2017 86. I did the procedure for turning on hill assist but it doesn't come on. According to my dealer sticker, and the toyota website, Hill assist is also available on an automatic transmission. It would be nice not to chirp the tires when switching from the brakes to gas on a 30 degree incline. Supposedly the brakes are automatically activated for 3 seconds, making it convenient. Last edited by pcguru2000; 08-31-2018 at 04:15 AM. |
yerp
Drives: 2015 WRX
Don't have an AT so I can't speak to 2 or 3, but it's an inexpensive sports car so get used to popping, ticking, buzzing, and otherwise unrefined noises in the car. Just crank up the music and/or install more loud in your exhaust.
The Gunshine State
Drives: '14 BRZ Limited
Because budget racecar.
200*F is normal for idle, I think are t-stats open up around 203.
![]() Current DD: M235i |
A. Welcome to Subaru ownership
B. That's normal, radiator in this thing is well sized, rock solid coolant temps even when flogging hard, nothing to worry about until you start hitting the track. C. No idea if you followed the users manual, aside from re-reading that there's always the handbrake or your left foot. |
#5 | |
Senior gif poster
Drives: 2013 Asphalt FRS
Thanks everyone for a quick response.
Welcome to the gang, there, pcguru2000 ..........
![]() As far as the noise behind the dash, I suggest you have your wife drive and you be the gunner, armed with a spray can of silicone with a long barrel, a microfiber rag and a small plastic probe ........ and go squeak hunting. Back-in-the-day, I used to squeak hunt with several narrow shingle wedges. I would isolate the squeak and shove a wedge in its mouth to shut it up, then simply snap or twist off the unused part of the shingle wedge. ![]() humfrz |
#9 | |
Drives: DE5 Integra Type S
mostly this
"Precision without speed is empty, speed without precision, chaos."
| Tags |
| hill assist |
| Turn Signal Relay Question (Dumb Question) | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-23-2017 01:58 AM |
| Question for the the 2014 Brz Nav Owners (BT Question) | jbsali | Electronics | Audio | NAV | Infotainment | 3 | 07-16-2014 11:41 AM |
| BEspoke question and rattle question | bdanisi | Electronics | Audio | NAV | Infotainment | 2 | 01-30-2013 02:11 PM |
| HID question | mrlewistan | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 12-31-2012 07:49 AM |
| mpg question | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-10-2012 01:40 PM |
