225/45/17 or 235/45/17 For 8inch wheel
Wondering which you guys would prefer on a 8 inch wheel. Looking at the firestone Indy 500.
Would you highly recommend against stretching the factory 215/45/17 on them? |
Drives: Car
225/45/17. I would not advise 215/45 on an 8" wheel.
[insert cool phrase here]
Drives: BRZ Premium
The 235/45/17 would be a bit taller. It might throw your speedo off a bit. Go with a 235/40/17 if you want the 235's.
Or go with the 225/45/17. Which ever you want. I do not recommend stretching out that 215 on 8" wheel. It looks super weak. Unless you love the hellaflush/stance look. Tire choices, depends what you want out of them. Although I encourage anyone to avoid MPSS if you can't get them for under $130. Price vs performance compared to others it's not worth it. I highly recommend you use the comparison tool for the price and performance on any tire.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 2015 Scion FRS - Raven
I use 215/45-17 RE71R’s on a 17x8 wheels. I haven’t had any issues over the years at the track. I have been through about 3 sets of tires on the same setup. The tire is rated for a 7-8” wheel so I don’t see the issue with it. Run the 215/45-17 save some money and enjoy the steering response.
Little Member
Drives: Bloo - The 13' BRZ
I know specifically the Indy 500 runs a little thin to begin with. The tread width on my 245/40r17 is a touch over 8" wide. You can see pictures of them mounted in my thread, link is in my sig. they are not pinched on my 17x8 wheels and sit fairly square. Unfortunately I do not believe the Indy 500 comes in 235/40 which I would have recommend, unless they have done size expansions recently. 225/45 my sit slightly stretched, but should keep the sidewalls stiffer and should drive pretty well, as long as the slight stretch doesn't bother you.
Rice King
Not really sure about the recommendations against 215/45/17 on an 8 inch. They look absolutely fine, not stretched, and are a size documented to be under normal functionality.
Page 4 has an example of 215/45/17 on 8". http://www.ft86club.com/forums/showt...=121927&page=4
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
Drives: 2017 Brz
BFG comps in 215/45 have 8.1 inch tread width according to tirerack...I'd like to see that on an 8in wheel...probably look just like a 225/45 indy 500 which is 7.7 inches in width.
I've used the following:
8" - 215/45/17 - 225/45/17 - 235/40/17 9" - 235/45/17 They're all fine. (215/45/17 on a 17x8 is actually within the recommended wheel width range, at least for the tire I was using). On the street I like 235/45/17 for the thicker sidewall, but it's a slight difference at best.
2022 BRZ Build 2013 FR-S Build |
| Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes | Pat | Tracking / Autocross / HPDE / Drifting | 86 | 07-16-2021 10:50 AM |
| FS: Sparco steering wheel setup/ b2autodesigns wheel adapters | sebastiansim | NY / NJ / CT / PA | 1 | 11-12-2015 07:57 AM |
| Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge | DAEMANO | Wheels and Tires | 4 | 07-09-2014 01:35 AM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 11:34 AM |
| NRG Rim/Wheel LIP PROTECTOR up to 22" Wheel - Various Colors - FREE SHIPPING!!! | YURparts | Wheels and Tires | 3 | 12-16-2013 09:07 PM |
