Old 03-30-2018, 10:15 PM   #1
TOPEC
OEM alignment adjustment?
Looking for some insight on what can or cannot be adjusted and their limits on a completely stock 2013 FR-S. Trying to achieve -1.5 to -2 degrees of camber up front and -1 to -1.5 degrees in the rear, 0 toe all around. Can these specs be achieved without aftermarket parts, if not, will front SPC camber bolts and rear whiteline camber kit do it? This will be a daily driven car with no plans of tracking or autox, just purely spirited driving, future plans may involve RCA yellow springs or ST coilovers but that is a big MAY. TIA!
TOPEC is offline   Reply With Quote
Old 03-31-2018, 01:52 AM   #2
strat61caster
strat61caster's Avatar
No factory camber adjustment, you're on the right track though. -2 and -1 would probably yield a more balanced car, but that's not necessarily a good thing for public roads, and you'll have a little bit of camber wear on the front, but no issue really. -1.5 F/R might be a good compromise.
http://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
wparsons (03-31-2018)
Old 03-31-2018, 03:01 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
100% OEM camber is not adjustable, only toe is. Camber can be changed by parts that add adjustability and by lowering (increases neg. camber too by fixed amount).
But as rear camber in oem alingment is about -1.2, then it's rather close to what you need. Just get camberbolts for front (single set for to -1.5, camberbolts for both strut holes for up to -2.3). Rear camber adjusting .. it's PITA with camber bushings, better go straight away for cheaper LCAs like Whiteline/SPC/Eibach, or use stock -1.2, if it's even enough between sides.
The Following User Says Thank You to churchx For This Useful Post:
Old 03-31-2018, 02:10 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
You will pay the difference in labor using the whiteline bushings vs SPC/Whiteline rear LCA. You may also need to find a new shop every time you do an alignment... they SUCK to work with, or so goes the word on the street.
SPC camber bolts in the front bottom hole. Front lower 14mm bolt to the top 16mm spot (14mm up top is in the service manual).
Maybe a touch of rear toe-in.
Old 03-31-2018, 03:31 PM   #5
humfrz
I'd suggest you just leave that puppy alone, with the OEM specs.
humfrz
ls1ac (03-31-2018)
Old 03-31-2018, 06:24 PM   #6
TOPEC
thank to all for the advice, will look into the LCA. looks like 08+ wrx LCA from SPC will fit the FRS? just came across a used set for sale lol.
humfrz
whats wrong with running more camber for street use?
Old 03-31-2018, 08:12 PM   #7
humfrz
I don't reckon there is anything "wrong" with it ....... I just figure that the engineers who designed the suspension, figured that that range of adjustments were best for stability and tire wear.......
humfrz
Old 03-31-2018, 09:01 PM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
humfrz
Meh. Not if you drive hard, enough. You'll wear the outer edges of the front tires because not enough negative camber.
I'd wager it's a pretty big safety play in the mix, and a little comfort; steering that goes where you tell it (far more than stock) isn't what people expect - and camber tends to follow a bit more on the road as well, so takes more attention.
C
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (03-31-2018)
Old 03-31-2018, 09:17 PM   #9
humfrz
C
Oh, I was just going on how the OP says he plans on driving his car:
"This will be a daily driven car with no plans of tracking or autox, just purely spirited driving,"
So, if more negative camber is better ...... why wasn't the car set up that way in the first place ......??
..... help me out here .......
humfrz
PS - I'll have know, there sonny, I'm not a stranger to negative camber ......
cjd (03-31-2018)
Old 03-31-2018, 09:37 PM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
lawyers
humfrz (03-31-2018)
Old 03-31-2018, 11:55 PM   #11
TOPEC
factory alignments are almost always tailored to the general public, which usually means its on the conservative side. manufactures want people to understeer head on into a tree having the front of the car take the hit at the limits rather than oversteer sideways into a tree. imagine how many law suits manufactures have to deal with if everyones oversteering into trees because the public sees the car as "unsafe" or "unpredictable" at the limits where as people who understeers into an accident, the general public will see a dumb driver whos over speeding.
The Following User Says Thank You to TOPEC For This Useful Post:
humfrz (04-01-2018)
Old 04-01-2018, 12:15 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Understeer bias as most commong oem alignment is one thing, and also manufacturers want not most grip in curves, but for least possible tire wear (at daily driving), which is from closer to 0 camber. Also 0 camber may work better in low grip such as on gravel/ice/snow.
It's complete opposite to performance/track use though, where grip in curves is limited by insufficient camber to compensate tire sidewall flex and tire outside will be worn/ripped. Understeery front pushing out also won't help much getting through tight turns faster.
Hence imho it's best to have some middleground. Less understeer bias vs oem & camber somewhere in middle, between oem choice and track dedicated camber. That also seems what many are suggesting of.
humfrz (04-01-2018)
Old 04-01-2018, 12:22 AM   #13
humfrz
Interesting theory ......
humfrz
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
►►THE DEFINITIVE COILOVER and ALIGNMENT ADJUSTMENT THREAD◄◄ Best Prices on FT86Club!! CygnusPerformance.com Brakes, Suspension, Chassis 31 08-01-2013 06:28 PM
