Old 03-30-2018, 06:34 PM   #1
eddwvrd
Drives: Frs
2nd gear cold start problem
Has anybody experienced their 2nd gear making a clunk/metal noise? Everytime i cold start my car until it warms up and drive it first thing in the morning its kinda hard to shift it to 2nd gear and makes that clunk/metal noise(which is kinda embarrassing when people hear it and be like oh this dude is new to stick shift/irritating. But after a few minutes of driving the 2nd gear is smooth to shift and doesnt make that sound. Idk whats the problem but im guessing i should change the transmission and differential fluid? I already complain this to the dealer but the mechanic said it was normal. Anybody knows how to fix this problem?
eddwvrd is offline   Reply With Quote
Old 03-30-2018, 06:43 PM   #2
FryinBerries
FryinBerries's Avatar
Mine does this sometimes too. Not sure of the solution. I have a brand new transmission too
FryinBerries is offline   Reply With Quote
Old 03-30-2018, 06:50 PM   #3
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
This car is known for being hard to shift first/second gear when cold. Completely normal. I can't even shift into second if my RPMs are below 4k when cold.
As for the metal/clunky noise you're hearing: If it sounds like a heavy "thunk" coming from the rear when you shift into first, then that's normal as well. If it's more of a metal grindy noise, that could be a transmission problem.
Edit: Just re-read your post and saw that you hear when shifting into second, which I can't comment on.
What's your mileage? How do you use your car? Hard driving/track or daily drive?
Sent from my Pixel using Tapatalk
Beachin86 is offline   Reply With Quote
Old 03-30-2018, 06:53 PM   #4
whataboutbob
AutoX-10/10ths every run
https://www.google.com/search?q=ft86...w.ft86club.com
Build thread:Here
Old 03-30-2018, 06:53 PM   #5
Decep
Drives: 2013 FR-S Series 10
upshift no. downshift, i could force it but i rather double clutch.
Old 03-30-2018, 07:02 PM   #6
eddwvrd
Drives: Frs
@Beachin86 the has 35,000 miles when i bought it from toyota and right now 37-38,000 i think. Yeah it makes that “thunk” sound. Did you by any chance change your transmission fluid? Also im wondering why my friends brz is diffirent from mine like shifting the gear is much shorter and pressing the clutch to the floor is light and shorter too while my frs kinda has a travel when pressing the clutch and a bit hard which is normal to me loll
Old 03-30-2018, 07:12 PM   #7
Impureclient
Drives: 2015 FR-S
Starting in here might help:
Engine, Exhaust, Transmission - http://www.ft86club.com/forums/forumdisplay.php?f=8
or
Issues | Warranty | Recalls / TSB - http://www.ft86club.com/forums/forumdisplay.php?f=72
Impureclient is offline   Reply With Quote
Old 03-30-2018, 07:43 PM   #8
humfrz
Yep, as others have pointed out, it's most likely the nature of the beast.
As your mechanic says "it's normal".
Some folks have had some luck by changing the transmission fluid.
I suggest you just let the transmission warm up a bit before you start driving ....... or just be patient with the 1-2 gear shift.
humfrz
Old 03-30-2018, 08:01 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
New game: try to break the world record for the most instances of the word 'Normal' in a single thread. I see we are off to a good start.
My contribution: It's normal.
Old 03-30-2018, 08:02 PM   #10
shellslinger
Drives: Whiteout FRS
I've been using Motul transmission fluid for the past 3 - 4 years and never really experienced that 2nd gear clunk after switching out the factory fluid. When I was using factory transmission fluid it would get that clunk when it was cold.
shellslinger is offline   Reply With Quote
Old 03-30-2018, 09:10 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Master the quick 1-2 flick for minimum force.
Master double-clutching your way through missed/down shifts.
Getting smooth with this cold transmission will make you a MT jedi.
Old 03-30-2018, 09:29 PM   #12
Lantanafrs2
Drives: 2013 frs red
These things make every friggin noise possible. Hard to believe they were made in Japan. If they were European we would celebrate the noises as part of the "driving experience " lol. In reality it's just part of owning a 25k sports car.
Old 03-30-2018, 09:34 PM   #13
humfrz
Either just toot the horn between the 1-2 shifts......
OR
start off in 2nd gear ......
Fixed .....
humfrz
Old 03-30-2018, 09:38 PM   #14
StraightOuttaCanadaEh
Wes
Shift it back and forth while standing, in the morning, before you get going. Just a few times from first to second and vice versa. Spreads that lube nicely (hehe)
Instagram: @gt86ws
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
