Old 03-26-2018, 04:29 PM   #1
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
2017+ 3rd brake light 3 flashes from factory?
A question for those with 2017 or newer 86/BRZ. Does your 3rd brake light flash 3 times when you first brake?
So I bought a very lightly used 860 Special Edition (5 months old, under 5k miles). Looking in the trunk last night and it looks like the module that makes the 3rd brake flash is very visibly added and not part of the original wiring harness. There are no other mods done to the car, so I doubt the previous owner did it. Maybe added at the port when it arrived or maybe at the dealership?
Does yours flash? Do you have this module in your trunk?
Aipex8 is offline   Reply With Quote
Old 03-26-2018, 04:34 PM   #2
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Looks like prior owner modded it to me... Do you have "tap to turn" as well? (I'm assuming this because I haven't heard anyone else mention this on their car and I'd assume if they wanted the flashing third brake light they'd possibly want the "tap to turn" feature as well.)
Subaru STI :
Last edited by Kimsey47; 03-26-2018 at 04:36 PM. Reason: Stating reason for assumption...
Old 03-26-2018, 04:42 PM   #3
Aipex8
No tap to turn (although I'm planning on adding the Diode Dynamics flasher that does that). I'm wondering if it's a regional thing though (dealer or port installed) because I've been noticing more and more cars around my area with the flashing 3rd brake light (random commuter cars, most likely not modded).
The Following 2 Users Say Thank You to Aipex8 For This Useful Post:
ERA (03-26-2018), Kimsey47 (03-26-2018)
Old 03-26-2018, 08:34 PM   #4
ls1ac
ls1ac's Avatar
That is an aftermarket unit, and looks like ijdmtoy.com unit.
Old 03-26-2018, 08:34 PM   #5
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
I notice a lot of random new cars have this feature here in WA as well.
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
ERA (03-26-2018)
Old 03-26-2018, 09:06 PM   #6
Elliotw
Elliotw's Avatar
Originally Posted by ERA View Post
I see it on random cars as well. Maybe a dealer option?
I could see it being a "dealer" option charging 500 extra for this safety feature and installing it on cars in their lots. I'm sure this is grey market for sure.
Old 03-27-2018, 03:37 AM   #7
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Correct me if I'm wrong... but in that picture, isn't that the proximity sensor for your trunk/smartkey?
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 03-27-2018, 07:38 AM   #8
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I believe you are right that the module on the right is the factory part.
It looks to me that the aftermarket module is the heat-shrinked chip on the left, with heavier gauge wires and crimp connectors.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Aipex8 (03-27-2018)
Old 03-27-2018, 12:08 PM   #9
Ebush
Drives: 2017 Hot Lava 86
I saw an 86 a few months ago with the flashing third brake light, it was a brand new car on a test drive. Haven’t been able to find anything about it being a factory option, but it was definitely installed By the dealer.
Ebush is offline   Reply With Quote
The Following User Says Thank You to Ebush For This Useful Post:
Aipex8 (03-27-2018)
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
Dome light flashes on door setting kmac_brz Issues | Warranty | Recalls / TSB 7 02-28-2020 08:04 PM
Valenti 4th Brake Light wiring for 2017 MY wasabiseaweed Cosmetic Modification (Interior/Exterior/Lighting) 1 11-11-2017 02:56 PM
Help! GCS 4th brake light on a 2017 Toyota 86! Bowie915 DIY (Do-It-Yourself) Guides 2 05-11-2017 09:15 PM
Engine oil light briefly flashes after start up shu5892001 Issues | Warranty | Recalls / TSB 6 09-24-2014 12:52 PM
