Old 03-23-2018, 12:05 PM   #1
jtice
Drives: Man
Send a message via ICQ to jtice Send a message via AIM to jtice Send a message via Yahoo to jtice
Help me choose an UEL Header (Subaru Rumble)
I have been researching headers trying to find what would best match what I am looking for, but as you can imagine, there are so many choices and combinations out there.
My main goal is to get that UEL Subaru Rumble, but I do not want it to be annoyingly loud, and do not want it to drone on the highway.
I am trying to find videos or opinions that are running an UEL with STOCK exhaust.
Everyone seems to have a different overpipe, exhaust, etc.
The catless seem to be too load, but again, most have other aftermarket parts.
I was considering a catless 1320 Performance header, but cant find a video of it on a stock exhaust.
Thanks for the advice.
jtice is offline   Reply With Quote
Old 03-23-2018, 12:11 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm running Tomei UEl, Miltek OP and Berk fast cat FP, the rest of the exhaust is standard UK spec. Its fruity in the higher rev ranges only, pretty standard on the noise front when cruising.
Old 03-23-2018, 12:23 PM   #3
Bkdshadow
Drives: 2013 Scion FRS
I’m running a gruppe-s UEL with stock everything else right now. Definitely makes the car sound more rumbly. I personally want to get a catback or axleback with this to make it louder, but with the stock catback it sounds good too. You get nice rumble from like 2500-4000ish RPM under load. Cold starts WILL be louder than normal, and even a little raspy, but only for less than a minute so it warms up. After that it’s completely fine. And for what it’s worth, the smell IS there, but to me it’s not bad at all since my front pipe is still stock (catted)
I think most on the forum would agree it’s the best bang for buck header since it’s basicaly a Tomei clone but cheaper
Here’s a video of it with stock exhaust:
Bkdshadow is offline   Reply With Quote
Old 03-23-2018, 12:23 PM   #4
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Tomei, JDL, or Gruppe-S UEL are all really good.
pgranberg11 is offline   Reply With Quote
Old 03-23-2018, 12:28 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Its fruity....
But what flavor?
via Imgflip Meme Generator
OR
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
JD001 (03-23-2018), SCQTT (03-28-2018)
Old 03-23-2018, 12:41 PM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
JDL absolutely!
[ame="https://www.youtube.com/watch?v=3Pi-mWhMhMc"]JDL UEL header stock exhaust brz/frs/86 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=ebSeY0PZxyQ"]JDL UEL Header, Stock Exhaust Sound Clips NARF's 2016 FRS Build - YouTube[/ame]
You should also consider JDL because of the high quality and lifetime warranty, neither of which you will receive with a 1320 or most others.
Avoid Borla at all costs, their quality is terrible and the welds on those break all the time.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Teseo (03-23-2018), TofuJoe (03-23-2018)
Old 03-23-2018, 12:51 PM   #7
jtice
Drives: Man
Thanks alot, that doesnt sound too bad at all. Does it drone much at highway speeds?
Old 03-23-2018, 12:52 PM   #8
jtice
Drives: Man
Originally Posted by ATL BRZ View Post
JDL absolutely!
That clip of the yellow BRZ sounds nice, its basically the sound I am after, ,,,, except that popping.
I dont care for loud popping or backfiring. That worries me about alot of these setups.
Old 03-23-2018, 12:57 PM   #9
Bkdshadow
Absolutely not. It basically sounds stock volume-wise IMO unless you get on it, in which case it s a little louder. Definitely not obnoxious, but sounds good.
I will say that there is a “hissing-ish” sound when it’s under load that I originally thought was an exhaust leak. But it’s just because the metal is thinner than stock, and I don’t really notice it too much unless the windows are down. Not sure if other headers are like that, but take that as you will.
Old 03-23-2018, 01:02 PM   #10
jtice
Drives: Man
Thanks alot for the input.
Hmm hissing you say, yea that is interesting. I am thinking about wrapping the header before installing it to help with heat, so that could help the sound also if it was due to the thickness.
Old 03-23-2018, 01:08 PM   #11
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
i dont wanna be "that guy" so i will probably just go UEL header as well and just get new exhaust tips for stock catback. i want the header for oft so i might convert to catback also if i can find a mild sounding combo. JDL seems to have lots of positive feedback
JustSomeGuy is offline   Reply With Quote
Old 03-23-2018, 01:14 PM   #12
Bkdshadow
Not sure where you live, but if you see pretty good weather year round you may also consider the CNT uel header. Probably the cheapest header that is pretty good as far as the reviews on the forum goes. I think I’ve seen people run them for a couple years but start to have some surface rusting issues. Just look up CNT header review for our cars and you’ll see all the input on here. You never know what you’re gonna get in northern VA so that’s why I went with the Gruppe-s. If I lived in a warmer climate I might’ve went CNT
Good luck with your decision
Old 03-23-2018, 01:51 PM   #13
jtice
Drives: Man
West Virginia, so yea, 3 metric shitons of salt on the roads every year
The Following User Says Thank You to jtice For This Useful Post:
SCQTT (03-28-2018)
Old 03-23-2018, 02:20 PM   #14
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
So a few things. It sounds like you are going to be running Stock CBE. That being said adding a catless header will barely increase your volume. I ran this setup for a while when i moved (i live right next a police station) and my car was actually quieter than my stock Focus ST.
Videos wont really help with volume cuz there are too many variables (microphone, how close the camera is, volume of your speakers).
But from experience i can tell you its barely louder than stock. I could gun it next to a cop and the only thing he looked at me for was my big wing.
Second, DO NOT cheap out on parts, especially something like a header. While the 1320 price may seem awesome. the quality of their parts are only about average. There are just as many fail stories as there are success stories.
If you want a high quality UEL header for the price you cant go wrong with Gruppe - S, Tomei, Openflash header. If you can afford more and go with higher quality, then you can go for something like JDL.
Both JDL and FT86Speedfactory offer a Catted UEL header. But expect to pay around 900+ for that.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
bababooey (03-26-2018), TofuJoe (03-23-2018)
Gruppe-S UEL Header Review...Subie-Rumble On A Budget dirtbike250x Engine, Exhaust, Transmission 8 11-02-2016 09:43 AM
UEL header rumble sound question FR-Sky Engine, Exhaust, Transmission 41 04-05-2016 02:28 AM
Bring out that BOXER RUMBLE with an UnEqual Length Header JonMotoring Groupbuys 1 02-26-2015 03:59 PM
Header or Headers? Choose your side now! FR-S Matt Engine, Exhaust, Transmission 8 09-23-2014 02:08 PM
subaru rumble V1B Engine, Exhaust, Transmission 25 07-13-2012 07:03 AM
