Old 03-21-2018, 06:22 AM   #1
dreeezy
Drives: FRS
Which coilovers for $1400 and under?
Been out of the scene for a minute now. Im looking for quality budget beast coils with a good drop. Which brand do you recommend? I see a lot of great feedback on the different manufacturers on here....
For DD and occasional track use, along with a swift upgrade if applicable...
KW v1
Fortune Auto 6series
Tein Flex A or Z
BC extreme low
MeisterR
Bilstein B14 pss
Etc.
Feel free to list anything Ive missed, thanks in advance!
dreeezy is offline   Reply With Quote
Old 03-21-2018, 06:50 AM   #2
jmark
Drives: '97 NSX-T, '18 Type R
GTWORX/BILSTEIN Trophy Cup Coilovers (comes with Swift and Lifetime Bilstein warranty) Will be more than $1400 and due soon.
CSG Tein Flex A (track tested by CSG and rebuildable) $1400
jmark is offline   Reply With Quote
The Following 2 Users Say Thank You to jmark For This Useful Post:
RL_BRZ (03-22-2018), Shark_Bait88 (03-21-2018)
Old 03-21-2018, 06:51 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
"Good" drop (if one does care about handling) is NOT very low drop, best to lower within 1". For that most will do.
churchx is online now   Reply With Quote
Old 03-21-2018, 06:55 AM   #4
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Parts by Max. Although they're more for drift
Sent from my iDroid
Jajanken86 is offline   Reply With Quote
Old 03-21-2018, 07:47 AM   #5
KW v1
Tein Flex A or Z
BC extreme low
MeisterR
Bilstein B14 pss
Etc.
https://www.counterspacegarage.com/t...gspec-toyota86
Old 03-21-2018, 08:08 AM   #6
For under $500 you can go with a good set of lowering springs that will be every bit as effective as coil overs. The only valid reasons to go to coil overs is if you need clearance or want to be able to change adjustments.
Old 03-21-2018, 01:41 PM   #7
dreeezy
Drives: FRS
Thanks for the feedback keep them coming
Old 03-21-2018, 02:24 PM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I suppose you mean the coil overs in the list ...
Old 03-21-2018, 02:46 PM   #9
Coil overs in general up to and including the most expensive. UNLESS you want adjustability or a certain combo of spring rate and damping that only coil overs can give you.
Cole (03-21-2018)
Old 03-21-2018, 05:56 PM   #10
Submarinesonce
Drives: Frs
I disagree. they'll get you low, but the stock damper with most lowering springs wont be well matched to the spring like a coilover is. that said, for 1400, id absolutely buy the CSG Flex A
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 03-21-2018, 06:09 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
My used T2s with 25,000 miles on them.
Old 03-21-2018, 06:32 PM   #12
If you buy the quality springs they are pretty well matched. Buy the cheap ass ones and you may as well be throwing random parts on. Same applies to coil overs though. Let's keep in mind that unlike throwing springs on a base Civic these cars are starting out with a much better than normal stock shock. I know everybody likes to throw stuff at the car like it is a 15 year old low trim sedan but you are not working with the same low end stuff.
finch1750 (03-21-2018)
Old 03-21-2018, 07:19 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I run Flex Z's. I was really hesitant to buy them because they are one of the cheaper coil overs out there. I am very happy with them. They ride very well, the car feels very stable and planted on track. Even when taking a bunch of curb mid corner on a downhill that cambers to the outside.
My previous setup was H&R springs on stock dampers.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
D_Thissen (03-21-2018)
Old 03-21-2018, 08:06 PM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The OEM suspension is acceptable and there were also revisions to make it a bit different. Nevertheless, such a suspension either it is branded by Showa or Sachs, it is still made under the same strict 'general maitenance schedule" and cost guidelines of a production car so I wouldn't consider it the best available or in general better...
For sure, not to an extent a true performance driver will call it outside the PR talks, a performance suspension.
Broadway Static Coilovers for sale $1400 OBO ErickR1007 Brakes, Suspension, Chassis 1 05-26-2017 03:29 AM
NORCAL - ADVAN RS II $1400 with tires lakestreet Wheels and Tires 15 12-24-2016 06:13 PM
RE: Vossen CV3 19x8.5, 19x10 $1400 FRS_GT Wheels and Tires 17 09-03-2014 02:52 AM
Fastest BRZ In The World? 7 Second 1400 HP BRZ Goes for Record at LVMS Hachiroku BRZ First-Gen (2012+) — General Topics 54 05-21-2013 07:31 PM
