Old 03-21-2018, 02:03 AM   #1
Purist
Purist's Avatar
Drives: Subaru BRZ
HOW TO LAUNCH FOR AUTOCROSS
Hey all, just wondering how you guys launch off the line for good autox times. Low revs high revs, dump the clutch ? Use OFT or Ekutek 'launch control' (which isn't even launch control)...?
My hillclimb has a conctrete startline, super slippery, and the first corner is really soon after.
Less More
Purist is offline   Reply With Quote
Old 03-21-2018, 03:13 AM   #2
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
It depends. While I personally like to launch at around 4-5k, a lot of fast autocrossers don't even launch the car at all. In your case I don't even think an aggressive launch would even help at all. Only at drag race starts does launching matter. Even then you wouldn't win a race because you had superior launches because you still have to drive the course.
[ame="https://www.youtube.com/watch?v=h3jV_vNLAkw"]SCCA Pro Solo Practice starts @ Crows Landing 4-24-15 Subaru BRZ MY2013 - YouTube[/ame]
doggieboy09 is offline   Reply With Quote
The Following User Says Thank You to doggieboy09 For This Useful Post:
Purist (03-22-2018)
Old 03-21-2018, 07:13 AM   #3
Submarinesonce
Drives: Frs
I disagree, I always describe autox as drag racing with corners. some layouts don't lend themselves to hard launches, but on layouts with a good run to the first element, you could pick up .5 secs or so just based on launching hard and getting to race pace vs pulling away gently. all that said, I set the OFT LC to about 4000 RPM and slip the clutch when I can launch hard at an autox.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
The Following User Says Thank You to Submarinesonce For This Useful Post:
Purist (03-22-2018)
Old 03-21-2018, 08:36 AM   #4
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Most starts for non-proSolos are designed (*are supposed to be designed) to remove drag starts so one car wouldn't have an advantage over the other because of the start favoring more powerful or traction favored vehicle. After the start, before the lights or near the lights is supposed to be a turn that removes any advantage to a fast start.
Most (again, not all - YMMV) should be just a brisk start to get up to speed, but shouldn't require high revs or anything that should accel wear.
Do a search for Roger Johnsons Course Design Handbook, essentially listing the golden rules for *safe* and good course design parameters.
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
The Following 2 Users Say Thank You to Imp For This Useful Post:
dradernh (03-25-2018), Purist (03-22-2018)
Old 03-21-2018, 10:44 AM   #5
justint5387
Drives: 4 wheels
I use the ECUTEK "launch control" for maximum wheel spin at Pro Solo, which is not the fastest way.
For regular autocross, I almost never launch it unless it's a national event and the course calls for it.
justint5387 is offline   Reply With Quote
The Following 2 Users Say Thank You to justint5387 For This Useful Post:
G_Ride (03-22-2018), Purist (03-22-2018)
Old 03-21-2018, 11:44 AM   #6
Lex_K
Drives: 987S, e46, mkv, frs
I find that the car gets off the line best at around 4K with mild clutch slip then letting off to get a little wheel spin.
Lex_K is offline   Reply With Quote
The Following 3 Users Say Thank You to Lex_K For This Useful Post:
bdtbdtbdt (03-22-2018), Purist (03-22-2018), strat61caster (03-25-2018)
Old 03-22-2018, 07:22 AM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
I tried the OFT version but it goes to normal rev limit at something like 20km/h so no point IMO.
Less More
Old 03-25-2018, 12:17 PM   #8
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Even at national courses with a 90 degree bend at the start, I rarely find myself having to lift at the first corner that was designed to prevent a drag race start. Something about our cars not having much power...
FWIW, I was a 4k rpm launcher until I was getting crushed by David Marcus at the '15 Wilmington Pro off the line. He said bump it up to 5k which I did, ended up matching his 60' times. I think it all depends on surface and tire selection.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
TrqlessWonder (03-26-2018)
Old 03-26-2018, 05:39 PM   #9
hpde_addict
Drives: '18 Camaro V6 1LE
I noticed 0.5-1s difference at a BMW club Mariana Airport event with launching vs. no launching. That being said, I think launching is pointless unless you are fast enough to win your class and willing to pay for axles :P
hpde_addict is offline   Reply With Quote
Old 03-26-2018, 05:48 PM   #10
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've been launching my car from 3-4k RPM at every autocross event for 3 years now (2 of those years on 245 section RE71Rs) on a lowered car, and have yet to experience any axle issues. I don't completely dump the clutch. Just a really quick release that results in some minor wheelspin/shudder.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
trippinbillies40 (03-26-2018)
Old 03-26-2018, 07:21 PM   #11
trippinbillies40
Drives: '22 WRB
Hmm, I launched the shit out of my FRS for 3 years and never broke one. But I was never the lowest kid in grid either.
Old 03-27-2018, 01:30 AM   #12
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
It depends on the course and club whether or not launching makes a difference.
Try doing regular autox on grippier surfaces
You're also not as low as some other cars.
G_Ride is offline   Reply With Quote
Old 03-27-2018, 01:31 PM   #13
TrqlessWonder
Drives: 2014 FR-S
I'm starting season 5 with this car in CS trim. Lotsa side-step launching, first season was on A6s, rest on 235/245 bridgestones, still on the OE axles at ~77k.
IIRC, the guys breaking things were a bit more than "lowered"...closer to #stancenation levels of low.
If you launch the car harder/get going aggressively, I think you'd be pleasantly surprised how much closer to the front you get with just that change.
There absolutely are times when it would provide no benefit whatsoever. But, those are the exceptions to get depressed by, not the norm to expect.
Think of the courses where your first press of the brake pedal is like two worker stations in. If *everyone* is full throttle from the start lights to the entry of the same slalom/turn/other speed-scrubbing element, those going that extra foot/sec faster when they came across the start lights get there sooner. Manage to not make a mistake and give that time back, and you get to the finish lights sooner, too.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 03-27-2018, 01:37 PM   #14
Submarinesonce
Drives: Frs
all of this. go as fast as you can, as often as you can.
Fr-s launch RPM F3dzo Scion FR-S / Toyota 86 GT86 General Forum 14 04-21-2016 07:11 PM
the launch 7thgear Tracking / Autocross / HPDE / Drifting 9 07-11-2014 05:14 PM
FRS Out run 3.25 BMW from Launch Whitigir FR-S / BRZ vs.... 25 06-06-2013 05:42 PM
BRZ launch in NZ Metabrz BRZ Photos, Videos, Wallpapers, Gallery Forum 15 12-12-2012 08:00 PM
86 Launch in NZ caldine AUSTRALIA 0 09-15-2012 06:06 PM
