Old 03-18-2018, 02:09 PM   #1
Bread1
Drives: Scion Frs
Will a 17x9 Rota titan 42 offset fit on stock suspension?
Bread1 is offline   Reply With Quote
Old 03-18-2018, 08:41 PM   #2
scraejtp
Drives: 2013 Subaru BRZ
Depends on tire and camber, may rub.
scraejtp is offline   Reply With Quote
Old 03-19-2018, 11:32 PM   #3
rtang
Drives: 2017 86
I'm on stock dampers with TRD springs and I rub in the front at full turning lock. I have some 3mm spacers waiting to go on but haven't had a chance yet. Running Hankook Ventus V12 Evo2 245/40
rtang is offline   Reply With Quote
Old 03-23-2018, 04:50 PM   #4
Bread1
Drives: Scion Frs
245 40??
Old 03-23-2018, 05:02 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, on most cars. Though, a 3mm to 5mm spacer would fix any rubbing. I would run 245/40.
A guy in this thread says he does not rub with a 255/40 and lowered on sportlines. But, with only 3mm to the spring perch, there is no room for any camber...
Post #2299
http://www.ft86club.com/forums/showt...41083&page=165
I LIKE TIRES!
Old 03-27-2018, 11:04 AM   #6
Bread1
Drives: Scion Frs
Post #2299
So I will be good with these with a 245 40 on stock? Until I get some new suspension.
Old 03-27-2018, 12:32 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, and like I said before; a 3mm slip spacer added to the front will fix rubbing at full lock if it occurs.
I LIKE TIRES!
Rota titan 17x9 +35 offset fit stock suspension? Bread1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-14-2018 08:16 PM
New wheels - Rota Titan 17x9 justinco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-18-2017 01:30 PM
Rota Titan 17x9 +42 Leftyluff Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-21-2015 12:45 AM
Wheel Directory: Rota Titan 17x9.0 +45 SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-20-2015 08:15 PM
Rota Titan 17x9 +42 Black Continental ExtremeContact DW 245/40/17 toeout Wheels and Tires 11 02-16-2015 03:26 PM
