Old 03-16-2018, 07:27 PM   #1
Blue Gumby
Drives: 2017 86
OEM Bump Stop length
Can anyone please tell me what the OEM front and rear Bump Stop lengths are? I tried researching and found fronts are maybe 60mm?
Blue Gumby is offline   Reply With Quote
Old 03-17-2018, 07:41 PM   #2
scirocco78
Drives: Scion FRS
I think I have some in my shed I can measure. I'll look tomorrow and get back to you.
scirocco78 is offline   Reply With Quote
Old 03-18-2018, 12:35 PM   #3
scirocco78
Drives: Scion FRS
Ok, I have them. What need you need for measurements?
Old 03-18-2018, 01:32 PM   #4
norcalpb
norcalpb's Avatar
I can measure front RCE short bump stops if you’d like.
Old 03-18-2018, 02:26 PM   #5
Blue Gumby
Drives: 2017 86
I just need overall length of front and rear. I have some koni that I’m installing but want to purchase some aftermarket bump stops to test.
Old 03-18-2018, 02:54 PM   #6
86league
Drives: '13 BRZ Limited
Measured the stock ones I took off at about 20k miles to install the RCE yellow springs (they include new stops).
Front is about 57mm, and rear is about 59mm. Not sure if these have compressed a little during use.
86league is offline   Reply With Quote
Old 03-18-2018, 04:00 PM   #7
scirocco78
Drives: Scion FRS
I have just the opposite. Front is 59 and rear is 57mm.
I also have 2 RCE whites and one RCE blue for sale if you want them. The other RCE blue was cut up. For Science!
Old 03-18-2018, 04:18 PM   #8
norcalpb
norcalpb's Avatar
What are the whites and blues?
Old 03-18-2018, 04:21 PM   #9
scirocco78
Drives: Scion FRS
Oops my bad. I meant RE Suspension
http://resuspension.com/index.php/bu...ot-series.html
Old 03-18-2018, 04:29 PM   #10
norcalpb
norcalpb's Avatar
Oh I see. RCE likes to color label their springs blacks, yellows, grays (ok I made up grays, but that’s the color of the tarmac springs lol)
Old 03-19-2018, 03:09 AM   #11
Blue Gumby
Drives: 2017 86
What’s the ID of those? I would think there’s a big difference in shaft diameter between front and rear
Old 03-19-2018, 07:02 PM   #12
scirocco78
Drives: Scion FRS
Yes there is a big difference. They would need to be drilled out.
Old 03-19-2018, 09:09 PM   #13
86league
Oops - you are right... I had them mixed up. Front is 59+ and the rear is ~57 including the 4 nubs ~55 without. Front ID is 21.5~, Rear is ~15.3
Eibach Pro Kit Bump Stop Question rebsinfx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-12-2016 03:58 AM
TOMEI HEADERS EXPREME UNEQUAL LENGTH / EQUAL LENGTH AND JOINT PIPE FOR FRS/BRZ myjdmparts Groupbuys 85 10-07-2015 02:17 PM
Eibach Sportline bump stop length DAEMANO Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-01-2014 12:12 AM
?equal length or unequal length headers? subaruferrucci Engine, Exhaust, Transmission 22 07-11-2013 12:56 AM
bump mrnibbs Site Announcements / Questions / Issues 5 06-25-2013 01:29 PM
