Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Hey guys,
Finishing up my shorai install and i've hit a bit of a snag. The positive wire that connects to the battery cannot be tightened down enough to make a solid connection. Suggestions? picture:
Drives: 13 BRZ, 18 STI
Did you have to install the brass connections on the terminals for the shorai battery? If so, they are two different sizes. The positive one should be larger, and the negative one should be smaller. That's how it was on my braille battery I installed a few days ago.
Racecar spelled backwards is racecaR, because RacecaR
#3 | |
humfrz for Bubba |
I went with this.
Drives: Car
Looks like it fits fine? Seems like for the nut on the positive terminal you're actually missing a square washer.
#6 | |
Drives: Car
@Elliotw Just took a picture of my 11lb Braille battery. Right is positive; left is negative. What humfrz said ain't a half bad idea either. You could take it out and sand down the bit to allow the nut to move if you can't find a washer/spacer.
| The Following User Says Thank You to FirstWinter For This Useful Post: | humfrz (03-08-2018) |
finished product. added some nice 3m electrical tape so no metal on metal contact.
Drives: 2017 Series.Yellow, 2005 LGT wagon
Since you already have it sorted out, this is probably irrelevant, but as someone already stated, it looked like you were missing one of the square washers on the connector. That probably would have given you the extra clamping force needed to secure the connector to the terminal. I didn't have this issue with mine.
| DIY: 5lb Shorai Battery Install | industrial | DIY (Do-It-Yourself) Guides | 157 | 01-11-2024 11:49 AM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 01:07 AM |
| KC Machine Tray and Shorai battery + Shorai Charger | toeout | Engine, Exhaust, Bolt-Ons | 0 | 02-15-2015 06:34 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
| Shorai Battery, Tender, and PTuning Tray | jack43 | Engine, Exhaust, Bolt-Ons | 4 | 08-23-2014 12:42 PM |
