Old 03-07-2018, 07:48 PM   #1
Flame9020
Drives: 2015 Scion FR-S
Stripped Wheel Bolt
I was changing my wheels the other day and noticed that all but one lug nut would torque to 100ft.lbs. The last would just spin and spin and spin so I think the bolt might be stripped. This happened with two other nuts I tried. I can crank it down until it tightens but then it's extremely hard to remove.
Questions are:
1. If the bolt is stripped where can I buy more/what part is it?
2. Are there bolts that are better/less prone to stripping than the stock bolts?
Flame9020 is offline   Reply With Quote
Old 03-07-2018, 07:57 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
1) 100 ft-lbs is way beyond spec. 2) the damage was probably done by the last person to put the wheels on (cross threaded) 3) the lug nuts might have stretched threads and that's the issue with them not wanting to back off.
guybo is offline   Reply With Quote
The Following 4 Users Say Thank You to guybo For This Useful Post:
BirdTRD (03-08-2018), Flame9020 (03-07-2018), Leonardo (03-07-2018), Spuds (03-07-2018)
Old 03-07-2018, 08:01 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just replaced all of mine with a ball joint separator. It was fairly easy. i got extended ones, so dont have a part# for you.
I LIKE TIRES!
Old 03-07-2018, 08:08 PM   #4
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
you can purchase a new stud from your dealer but they are prone to stripping
APR makes a more solid stud
http://www.ft86speedfactory.com/arp-...l#.WqCM4WrwZhE
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Old 03-07-2018, 09:11 PM   #5
Teseo
Drives: frs
A pie-size of antiseize on threads for next time makes wonder too
The Following User Says Thank You to Teseo For This Useful Post:
Erick KY (03-10-2018)
Old 03-08-2018, 04:56 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Thumbs down
never use any grease or antiseize on lug studs! They go on dry because anything on the studs changes the torque. Plus they are designed to seize up to a point- you don't want them backing off
The Following User Says Thank You to guybo For This Useful Post:
humfrz (03-08-2018)
Old 03-08-2018, 05:17 AM   #7
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
1) Factory spec is around 89 ft-lbs.
2) You've likely stripped the stud if you can free spin and it's not getting any tighter. That's a more labor intensive job than simply finding a new lug nut. You're going to need a press to get that thing in. I would recommend upgraded studs like ARP.
tyler_win_photo is offline   Reply With Quote
Old 03-08-2018, 11:49 AM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
ARP studs require removal of the hub FYI. There is a DIY one the forum how to do it without a press, but a press is the correct way.
For now the OEM from the dealer is cheap and can be installed while it is still on the car (if in the rear you just need to rotate the hub around to get clearance to pull it out the back). Then use the washer method to install. And you might need a new lug nut while you are at it
Old 03-08-2018, 12:15 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
A ball joint separator will easily remove and install the lug studs without removing the hub. A press is nice, but not necessary. I did all 20 of mine in an hour.
I LIKE TIRES!
Tristor (04-18-2018)
Old 03-08-2018, 01:27 PM   #10
wparsons
wparsons's Avatar
You can install stock or extended in the front like that, but only stock length in the rear. To get the ARP studs in the rear you have to pull the hub out of the knuckle.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
DAEMANO (03-08-2018), Tristor (04-18-2018)
Old 03-08-2018, 01:40 PM   #11
DAEMANO
Time Traveller
This is the correct answer
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 03-08-2018, 01:42 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just took off the rear rotor to get to them. I installed extended studs.
EDIT: I did not install ARP studs. If there is something different about them, I could be wrong about the process working with them. Mine are Ichiba +5mm rear studs that I installed with the ball joint tool. Additionally, there is zero way to mess up the threads using the ball joint separator to install over the "washer method".
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Tristor (04-18-2018), wparsons (03-09-2018)
Old 03-08-2018, 03:20 PM   #13
finch1750
finch1750's Avatar
ARP studs are about 2" longer then stock. They will not clear for the install without removing the hub in the rear
What style ball joint tool did you use? I see 2-3 kinds when I google it and have only used a fork myself
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Leonardo (03-08-2018), Tristor (04-18-2018)
Old 03-08-2018, 03:32 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
[ame="https://www.youtube.com/watch?v=NEYz3Z8rHgo"]Lone Wolf Racing Honda S2000 Using a ball joint separator to remove wheel studs - YouTube[/ame]
Press out the old, flip tool over, press in the new.
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
BirdTRD (03-08-2018), finch1750 (03-08-2018), Tristor (04-18-2018)
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Stripped bolt head at over pipe/front pipe connection, what now? :( BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 43 01-14-2019 06:13 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 02:29 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
