Old 03-05-2018, 08:10 PM   #1
CoolHandMoss
Drives: 2013 FRS
DIY Timing cover leak repair?
I've got a pretty decent timing cover/valve cover leak and not only do I doubt the dealership is going to honor a warranty on any part of my car, but I also just don't trust them. So I'm trying to compile all the information and parts I'll need to get the engine sealed up myself, but I've found next to no info from people that have done it. The FSM is helpful but bland as always. Has anyone done this that can share some advice learned during the process? Obviously there are plenty of seals and O-rings to buy before hand, valve cover gaskets and such. Are there any that aren't so obvious that would be easy to over look?
I'm also curious as to whether anyone has tried an alternate sealant that worked out well. I'm sure most will say the factory sealant is the only option but I'm not convinced considering how many failures I see reported. Might RTV Black be better? Does it need red? Any other suggestions? I definitely want to use the very best sealant I can that will have the lowest chance of leaking in the future.
CoolHandMoss is offline   Reply With Quote
Old 03-05-2018, 08:37 PM   #2
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
It's pretty involved to reseal it yourself. Lots of engine parts have to come out: air box, crank pulley, alternator, A/C compressor, water pump, header, part of engine harness just to access the 25+ bolts that hold the front timing cover on. It is a royal PITA if you're attempting to do it yourself.
For sealant, Subaru has Fujibond. There's also something called Threebond. And Hondabond is a pretty good sealant as well from my working on Honda days.
Here's the TSB for it: http://www.ft86club.com/forums/showp...&postcount=187
Si_Chris is offline   Reply With Quote
Old 03-05-2018, 08:43 PM   #3
CoolHandMoss
Drives: 2013 FRS
I'm actually planning to just pull the engine out and do a new valve cover gasket on one side and spark plugs all at once and have plenty of space to make sure to get everything clean and perfect. Half the reason I'm not going to the dealer is that I don't want it to ever leak again haha.
Thanks for the suggestions.
Old 03-05-2018, 08:54 PM   #4
humfrz
Well, CoolHandMoss, have you had experience taking a newer engine apart and putting it back together ... ??
Not doubting your ability ...... just curious.....
humfrz
Old 03-05-2018, 09:28 PM   #5
CoolHandMoss
Drives: 2013 FRS
humfrz
No, but I borrowed a tool kit from my dad so I'm set.
The Following 2 Users Say Thank You to CoolHandMoss For This Useful Post:
gravitylover (06-06-2019), strat61caster (07-09-2018)
Old 03-05-2018, 09:34 PM   #6
humfrz
Yes, tools are a good start .....
Does your dad live close and is he an experienced automobile mechanic .....??
Or, do you have a friend that is a auto mechanic ...??
humfrz
Old 03-05-2018, 09:42 PM   #7
CoolHandMoss
Drives: 2013 FRS
humfrz
Wait, do tinker toys count?
Old 03-05-2018, 09:47 PM   #8
humfrz
Tinker toys don't count but having an erector set would count......
Seriously, I'd just hate to see you get in over your head on this project ....
humfrz
Old 03-05-2018, 09:49 PM   #9
CoolHandMoss
Drives: 2013 FRS
Thanks for the concern.
Now, has anyone done this specific project that wouldn't mind sharing some experience based insight?
Old 03-05-2018, 11:06 PM   #10
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
I pulled the engine to reseal it, doing plugs sucked enough. It’s really straightforward if you’ve worked on other rwd cars, try removing the transmission and if that gives you hell just put everything back because resealing the engine is a beast on its own even after you pull it out of the bay.
86kahl is offline   Reply With Quote
Old 03-05-2018, 11:17 PM   #11
CoolHandMoss
Drives: 2013 FRS
So what sealant did you use? Did it work well?
Old 03-05-2018, 11:25 PM   #12
86kahl
86kahl's Avatar
Whatever subaru gave me at the parts counter... i wanna say it was a plain white or grey tube. I did my drivers side valve cover at the same time and so far (11k miles) it’s been leak free
Old 03-05-2018, 11:34 PM   #13
CoolHandMoss
Drives: 2013 FRS
Good deal. Thanks for weighing in. I'm all ears if you think of any other advice.
Old 03-06-2018, 02:35 AM   #14
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
I would imagine that you could reseal the timing cover on the car with all the accessory pulleys, radiator, condenser, crash beam, and upper radiator support beam removed.
As for what seals are required, I’d refer to the service manual for that...
kimcheefists is offline   Reply With Quote
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 4 04-03-2018 03:06 PM
Timing cover leak sid94 DIY (Do-It-Yourself) Guides 5 12-16-2017 03:19 PM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
