Old 03-01-2018, 04:10 PM   #1
fourseasonace
Drives: 2016 Scion FRS
Water bubbles damaged paint?
Hey so... no idea what happened here but after a car wash I noticed these spots, it seemed like the paint was cracked and water got underneath somehow but I'm not 100% sure. I dont know jack all about paint. I ordered touch up paint incase I might need that.
What is this?
What is the best way to make it go away?
fourseasonace is offline   Reply With Quote
Old 03-01-2018, 04:17 PM   #2
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
That is your clearcoat peeling right off the base layer. The high-pressure wash, in conjunction with what looks like a rock chip in the area, caused the damage. The rock chip gave the water an edge to lift.
FYI: This happened to my car from my very own power washer on the front bumper (also had a very small rock chip). I was conscious to keep the nozzle about a foot away too. The paint of these cars is fairly poor from the factory.
Jesse36m3 is offline   Reply With Quote
The Following 3 Users Say Thank You to Jesse36m3 For This Useful Post:
Leonardo (03-01-2018), Tcoat (03-01-2018), Teseo (03-02-2018)
Old 03-01-2018, 05:00 PM   #3
You could probably blast away at paint chips on the metal parts all day and never have an issue. Part of the issue on the plastic parts is that they flex a bit under the water pressure and the weakens the paint even more. This will happen on most cars with plastic panels and has little to do with the quality of the paint.
Old 03-01-2018, 10:12 PM   #4
fourseasonace
Do you think trying to seal the openings with touch up paint would be a viable solution?
Old 03-05-2018, 09:18 AM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
clear should never de-laminate from basecoat. Too much time between basecoat and clearcoat application, or chemical failure. If anything, the base and clear should be flying off the raw plastic as one, not separate. That has to be stripped completely, then painted over
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-10-2018, 11:16 PM   #6
NRXRaptor
And now you will never go to a touchless car wash again. I'd take that to a paint shop/body shop if you want it to look good again
NRXRaptor is offline   Reply With Quote
bumper, damage, paint, water
Fiberglass Air Bubbles Subwoofer Enclosure MenoSkyz Electronics | Audio | NAV | Infotainment 8 10-31-2017 01:58 AM
Check for bubbles... dem00n NY / NJ / CT / PA 8 03-06-2014 12:58 AM
Magic hydrocoating water paint mwjcyber Cosmetic Modification (Interior/Exterior/Lighting) 3 12-04-2013 10:14 PM
Already damaged paint... ktulu7 Scion FR-S / Toyota 86 GT86 General Forum 20 05-09-2013 08:13 AM
Paint Correction, Opti-Coating, Car Wraps, Paint Protection & Tinting - LI Detailers LI Detailers Cleaning and Detailing 1 12-27-2012 05:12 PM
