Old 02-28-2018, 01:32 PM   #1
Kouki86
Drives: 2017 86
Brake duct/Turn Signal Delete
Hi, I'm going to be swapping my 86 front bumper to an FRS one. My turn signals are integrated with the headlights, so that leaves an opening where the FRS turn signals are. I was planning on using the Innovated Dynamics brake/intake ducts, but they don't ship to Canada. Does anybody know of any other companies that make anything similar to this?
http://www.innovateddynamics.com/pro...e-intake-ducts
Kouki86 is offline   Reply With Quote
Old 02-28-2018, 02:41 PM   #2
7c8
They definitely ship to Canada. Try emailing them for a quote.
7c8 is offline   Reply With Quote
Old 02-28-2018, 03:38 PM   #3
Kouki86
Drives: 2017 86
Tried ordering and it said they dont. I'll try that though.
Old 02-28-2018, 05:31 PM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Just run the standard FRS bezel and wire white lights to the signal housings as pseudo fogs
EndlessAzure is offline   Reply With Quote
Old 02-28-2018, 06:57 PM   #5
Brayden_23
Drives: Asphalt 2015 FRS
http://www.ft86speedfactory.com/apr-...l#.WpdB5NIrK70
Brayden_23 is offline   Reply With Quote
Old 02-28-2018, 09:34 PM   #6
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
These look the most OEM and are less than $100
http://www.ft86speedfactory.com/oem-...B#.WpdmliJOnDs
Drambeenie is offline   Reply With Quote
Old 03-01-2018, 04:35 AM   #7
Kouki86
Drives: 2017 86
Trying to find something similar to what I posted that would remove the turn signal. Doesn't look like there is anything else available in that style.
Old 03-01-2018, 10:53 AM   #8
7c8
I'm in the same boat as you where I don't need the fog light or turn signal as well. I don't necessarily want a brake duct either. Let me know if you find something cool!
Old 03-01-2018, 11:50 AM   #9
Kouki86
Drives: 2017 86
Yeah, I'm probably not going to actually run ducting to the brakes either. This piece doesn't include any of that anyways. It's really more for looks. I was considering just making up some blank covers and having them painted, but I'm not sure how it would look.
Old 07-31-2018, 09:54 PM   #10
carlovestela
Drives: 2015 Firestorm FRS
So can i disable my turn signal in front bumper?
Cause i have the morimoto headlights which have turn signal built in.
What led white light you recommend?
carlovestela is offline   Reply With Quote
Old 08-01-2018, 11:25 AM   #11
EndlessAzure
Wheels for Brains
If you're running aftermarket headlights with integrated turn signals, the "clean" or "proper" way to wire them was to depin the turn signal wire and add it to your headlight harness (instead of a wire splice). In that sense, you're not necessarily "disabling" the turn signal, just relocating the wire.
White LED light model depends on the bulb/size you're running. I like to use JDM Astar these days for my LED lights.
If you're trying to re-use the turn signal housings, you'll need a 7444 bulb. You can either re-pin/splice from your fog light harness if you want to utilize the fog light switch. Or, you can might also be able to re-utilize the low running circuit on the front turn signal harness (since the front turn signal 7444 bulbs are dual-filament), but I think that would make your fog lights flash when your signals are blinking.
Old 08-01-2018, 01:45 PM   #12
carlovestela
Did you disable yours?
Old 08-02-2018, 02:24 AM   #13
EndlessAzure
Wheels for Brains
No. I use my stock turn signals
Break duct ( turn signal delete ) SmsAlSuwaidi Cosmetic Modification (Interior/Exterior/Lighting) 46 03-02-2018 11:27 AM
SOLD: FRS BrakeDuct, turn signal delete 6spd Exterior Parts (Aero, Lighting, Etc.) 6 08-22-2016 08:02 PM
Issues with Diode Dynamics brake as turn signal + reverse light module SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 12 12-21-2015 12:41 PM
JDM GT86 turn signal delete? SomeoneWhoIsntMe Cosmetic Modification (Interior/Exterior/Lighting) 11 06-04-2014 07:06 PM
