Drives: 2015 subaru brz series blue
Crawford Manifold Spacer
I recently bought and installed a Crawford manifold spacer. But after installing i went to go start my car and nothing. It turns over for a quick second from the fuel that was sent to the motor from the fuel pump priming. Just wondering what wiring harnesses i should check to see why car won’t start. If anyone else has installed this mod please reply.
Drives: 2013 FR-S, 2016 Miata Club
Did you zip tie the vacuum lines (2? big ones) coming from the back of the intake? Make sure one didn't pop off.
Drives: 2013 FR-S Argento
Did you attach ground for the DI module?
Drives: 2017 Toyota 86
Make sure you didn’t damage any grounds.
Drives: 2016 FR-S
| Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) | nelsmar | Engine, Exhaust, Transmission | 295 | 08-25-2018 04:19 PM |
| FS-Crawford Billet Intake Spacer | Exbrz | Engine, Exhaust, Bolt-Ons | 5 | 04-02-2017 08:32 PM |
| BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! | iA Performance | Groupbuys | 18 | 11-04-2014 05:25 PM |
| Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-03-2014 01:53 PM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 12:59 PM |
