Old 02-22-2018, 12:22 AM   #1
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Vinyl that willl match Whiteout 37J
Is there any off the shelf vinyl (Amazon) that will match the Whiteout paint? TIA!
iLuveKetchup is offline   Reply With Quote
Old 02-22-2018, 12:45 PM   #2
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
may i ask what for? i thought paint codes were unique where it would be hard to replicate that into vinyl?
JustSomeGuy is offline   Reply With Quote
Old 02-22-2018, 01:33 PM   #3
DAEMANO
Time Traveller
Paint codes are unique, but I have found that vinyl is also unique. The easiest way to find what vinyl from which company will match is to order samples from a company that sells vinyl from many companies.
My suggestion to @iLuveKetchup is to order samples from a company like Metrorestyling that has many shades of white vinyls. I think they have 50+.
https://www.metrorestyling.com/White...s-s/354470.htm
Samples are $1 each so I suggest ordering as many as you can to get as close as you can. Anecdotally, I have found exact matches for Raven/CBS and the old WRB when I followed the above procedure to find a match.
Old 02-22-2018, 01:41 PM   #4
JustSomeGuy
A Nobody
Drives: FRS
oh interesting, i may have to do this for my raven frs then. i wanna color match my interior trim. do you remember what the raven one was?
Old 02-22-2018, 02:04 PM   #5
iLuveKetchup
Drives: EFF JAY
Thanks so much @DAEMANO !
I just need a very small strip to cover the inside edge of the FRS Monogram headlights. I want to cover the corner much like how the BRZ headlights are covered by the front bumper (highlighted below).
Old 02-22-2018, 03:30 PM   #6
Keep in mind that even though the paint and vinyl colours may be identical the difference in finish may still make them look miles apart. This goes double for anything with a pearl or metallic finish. Close enough for small projects such as this but tough to do on a much larger scale.
Old 02-27-2018, 10:51 AM   #7
LeviDane
Drives: Toyota GT86 Pearl White
I tried with Avery Pearl white and it was close but not 'Cream' enough
LeviDane is offline   Reply With Quote
3M color match Jollyyy FR-S / BRZ vs.... 0 08-15-2017 03:59 PM
Beat Sonic Whiteout Does not Match JARE_ee Cosmetic Modification (Interior/Exterior/Lighting) 15 01-29-2015 02:06 PM
whiteout with vinyl wrap white carbon fiber bumper? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 0 04-26-2014 03:16 PM
Willl this work? Ymerej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-14-2014 11:24 PM
Proper way to Rev Match pinoyplaya Engine, Exhaust, Transmission 46 09-05-2012 01:09 PM
