Old 02-20-2018, 04:45 AM   #1
J41v33
Drives: fr-sexy
Angry 5 second rev hang at low rpm
So I recently went e85 (stage 2 e85 oft) on my car a few days ago, and I was having issues with my car idling (was happening with 91 as well but wasnt as bad), so I thought maybe the throttle body was dirty, so I took the intake tube off and discovered a bunch of gunk all over the back side and around the rim of the throttle plate. I took some throttle body cleaner and sprayed it down and wiped it up till it was clean. Did a reflash to reset the ecu and that idle issue went away.
But now when I drive off from first and then press my clutch in at around 2500rpm, the rev will hang there for almost 5 seconds before it even starts to go down.
my cars throw out bearing also started to make a supercharger type whine noise the same time this happened. Idk if it is all coincidence or what. Maybe I messed something up on my throttle body? I even noticed on oft after resetting my ecu, my throttle % was reaching 99% where before it was barely hitting 90%.
Things I tweaked on the e85 tune: cold start, tip in enrichment, and radiator fan. Not sure if any of those would have caused this weird rev hang issue. It’s been driving me nuts and idk what to do.
Someone help me!
J41v33 is offline   Reply With Quote
Old 02-20-2018, 12:35 PM   #2
MRCA1ST
MRCA1ST's Avatar
Drives: 2013 WRB BRZ 6MT
How many miles on it? Sounds like you have some blow-by or something along those lines going on to get that level of buildup on the throttle plate. Do you have a catch can?
MRCA1ST is offline   Reply With Quote
Old 02-20-2018, 12:46 PM   #3
steve99
Someone help me!
did you reduce both the maf correction after start in gear and in neutral tables. ?
if you don't it will idle rearly high when cold
Old 02-20-2018, 12:56 PM   #4
J41v33
Drives: fr-sexy
76k miles atm. The car idles like a dream now though so idk if its just the ecu trying to relearn everything again, but before when I would flash my ecu, it never did that during the relearn process. just ordered a catch can yesterday after the discovery
Old 02-20-2018, 12:57 PM   #5
J41v33
Drives: fr-sexy
good question lemme check that in a bit and ill get back. I'm at work right now.
but the thing is it still happens even when ive driven the car for over 20 minutes at operating temps.
Old 02-20-2018, 02:53 PM   #6
J41v33
Drives: fr-sexy
maf corrections were adjusted to the recommended values
Old 02-20-2018, 03:55 PM   #7
J41v33
Drives: fr-sexy
is it very easy to damage electronic throttle bodies? if its the throttle body that might be causing this maybe ill order a new one and see if that fixes it
Old 02-20-2018, 04:41 PM   #8
CoolHandMoss
Drives: 2013 FRS
That same thing happened to me when my TOB went out. Because the TOB is no longer a bearing, it's just a metal sleeve after it fails, it puts drag on the engine. The engine will hold the revs up to prevent from stalling under the extra load. I thought it was just the car at first because the TOB went out as soon as I got it but when I fixed the TOB the revs started dropping straight to idle.
You could test that theory by just holding the revs up in nuetral without the clutch then releasing the gas and you'll notice that it acts exactly like it should.
CoolHandMoss is offline   Reply With Quote
The Following 2 Users Say Thank You to CoolHandMoss For This Useful Post:
J41v33 (02-20-2018), jcw99 (02-21-2018)
Old 02-20-2018, 06:01 PM   #9
J41v33
Drives: fr-sexy
I hope this is whats happening. My throw out bearing and clutch kit is coming in soon so I hope it fixes it. That could also explain my 2nd gear grinding issues.
Can anyone else confirm that this is the case?
rev hang, throttle stuck
Does the BRZ/FR-S suffer from rev hang? Subie BRZ First-Gen (2012+) — General Topics 80 01-04-2025 08:56 AM
Who's down to hang out! BRZGM3 Northwest 9 01-30-2016 08:27 PM
Where to hang clothes.. fuddbutter BRZ First-Gen (2012+) — General Topics 39 10-27-2015 03:57 AM
Rev Hang Issue sw20kosh Software Tuning 4 11-10-2014 09:17 PM
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
