Old 11-03-2014, 01:39 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Rev Hang Issue
Anyone know a fix to this rev hang issue when the shifter is in gear but clutch is in?
If I am coming to a stop and clutch in, the revs will often time hang at 1.5 - 2k rpms. They will stop hanging if a. i put it in neutral or b. come to a complete stop.
If I cruise down the freeway and clutch in but leave the car in gear it will rev hang at 2k rpms.
No vaccum leaks as verified by pressure testing and smoke testing.
@ptuning
Old 11-04-2014, 05:05 AM   #2
s2d4
s2d4's Avatar
This has only happened to me when I added to much timing when I was trying to reduce cold start noise.
I remember seeing the delicious guys reporting this as well..
The Following User Says Thank You to s2d4 For This Useful Post:
sw20kosh (11-04-2014)
Old 11-05-2014, 02:07 AM   #3
MyRx
MyRx's Avatar
"Often" as in every single time? I have had this too and you're right, clutch is in/in gear and rolling to a stop. Not often in my case but when it does occur, I just blip the throttle and the rpms drop back down. I'll pay more attention to it. Interesting what it could be.
The Following User Says Thank You to MyRx For This Useful Post:
sw20kosh (11-10-2014)
Old 11-05-2014, 09:31 AM   #4
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Mine does it as well but Ive also ****ed with the cold start timing.
cruizin01 is offline   Reply With Quote
The Following User Says Thank You to cruizin01 For This Useful Post:
Old 11-10-2014, 09:17 PM   #5
sw20kosh
Every time yes. Blipping the throttle doesn't work for me but you are on Jamesm tune and I am on Toan tune so might be a little different.
I do know Delicious Tuning has stated that all their tunes eliminate the "rev hang issue" that has crept up recently.
The Following User Says Thank You to sw20kosh For This Useful Post:
MyRx (11-11-2014)
Does the BRZ/FR-S suffer from rev hang? Subie BRZ First-Gen (2012+) — General Topics 80 01-04-2025 08:56 AM
Where to hang clothes.. fuddbutter BRZ First-Gen (2012+) — General Topics 39 10-27-2015 03:57 AM
Does one of your exhaust tips hang a little lower than the other? alexand3r Engine, Exhaust, Transmission 0 06-22-2014 10:58 PM
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
