Drives: 2013 Scion FRS
Edelbrock vs JRSC for track
Common sense says JRSC. Edelbrock has the best power curve. Your thoughts?
Ohne Titel
Drives: 2017 BRZ PP ISM
Recommended Google search: jackson racing vs edelbrock site:ft86club.com
Example results: http://www.ft86club.com/forums/showthread.php?t=104032 |
I'm more interested in a more direct comparison regarding track capabilities. Things like IAT differences, heat soak, cooling, etc.
#4 | |
Even the SCCA thinks so; they're considered equivalent for STU class racing. The better question is, what is better for *you*? How much experience do you have, and what class(es) will you be racing in? The best part is, both companies offer fantastic support, and are both in SoCal. |
#5 | |
Right now, I see the differences as Edelbrock: - More low-end torque: better for DD and probably better mid range, but makes me wary about reliability - Warranty: only up to 30k miles on the car - Big power potential: can get up to 400+whp JRSC: - A little cheaper - Potentially smoother/better CARB tune - Smaller kit can run stock injectors on e85 (I think?), less $$$ |
You still haven't stated what your goals and/or classing and/or experience is.
#7 | |
I'd assume for somebody going big the Edelbrock would be a no brainer, but from my end the main advantage for it I see is the low-end torque for DDing. Sounds like there's not much difference in terms of track performance OotB. |
#8 | |
FYI, my car also fits into 86CUP street class, depending on how I trim it. Do you want power for track use, or so you can have fun on the street and go a little faster on track? You still have not really answered my questions. |
For the sake of conversation I submit two hypotheticals.
1) I am the reincarnation of Ayrton Senna and I want to go as fast as possible for as many laps as possible and I'm prepared to upgrade my radiator and add an oil cooler. 2) I have never been on a track in my life. I love how light and nimble my twin is but I'm frustrated by all the nothing that happens when I push the gas on the street so I decide to add a supercharger. Which would be least dangerous/ unreliable if I want to start going to track days in the car. Also assume I'm willing and able to add necessary supporting mods. |
#10 | |
2. Same as above; both are vetted for track use. Neither is going to fail and/or be unreliable for track use, and particularly not in the hands of a novice. You're nitpicking the two best superchargers available for that platform. It's not like you're trying to compare a Jackson to a Kraftwerks, or an Edelbrock to a Sprintex. |
#11 |
So, the answer to the OP, buy an F1 car. Glad we sorted that out
#13 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Not by a ton. I think up in Norcal we had one BRZ crack a header due to heat? The few Edelbrocks we've had so far havnt had any issues. Like stated earlier. These are basically cream of the crop as far as track FI goes. Cant really go wrong with either.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#14 |
Anecdotally it seems like a lot of Rotrex units fail. I honestly wouldn't consider it because I'm not a fan of centrifugal superchargers they seem to generally provide the most narrow powerband.
| JRSC E85 Delicious Issue | loiselle1987 | Forced Induction | 28 | 07-24-2018 01:14 PM |
| Anyone of JRSC or Edelbrock? | tian105 | Mid-Atlantic | 11 | 10-02-2017 11:56 AM |
| Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) | DarkSunrise | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-30-2017 11:39 PM |
| JRSC oil use | xsnapshot | Forced Induction | 3 | 03-27-2016 10:22 PM |
| close. bought jrsc | BRZ'13 | Canada Classifieds | 13 | 05-29-2015 03:46 PM |
