Old 02-19-2018, 01:06 PM   #1
cytogenesis
Drives: 2017 BRZ Limited
2017 BRZ Spacer and Coilover Help
Hey guys,
I'm looking to get some coilovers to lower the car and some spacers to space out the wheels to flush with the fender. I would like to avoid camber if possible.
If I get the Ichiba V2's (20mm front and 25mm back) and the ST coilovers for the back, can I achieve this? If so, how much do I need to drop it? An inch?
I am keeping stock wheels (for now) and getting some Michelin PS A/S 3+'s this weekend. So that's exciting .
Is there anything else I could be missing to get these properly installed?
I do not have the PP version. I am a super rookie so sorry in advance for the basic questions.
Thanks for any help you can provide!
Direct links to items:
http://www.ft86speedfactory.com/ichi...izes-1637.html
https://www.amazon.com/ST-Suspension...ustomerReviews
EDIT:
Also now considering these coils:
http://www.ft86speedfactory.com/bc-r...s-brz-213.html
cytogenesis is offline   Reply With Quote
Old 02-20-2018, 08:44 PM   #2
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Camber is a consequence of lowering, to correct camber you'll need camber plates or bolts in the front and lower control arms in the rear.
I would avoid those coils completely. The only coils I can wholeheartedly recommend in your price range are the Tein Flex A. Anything else won't be nearly as good.
mjanmohammad is offline   Reply With Quote
The Following User Says Thank You to mjanmohammad For This Useful Post:
Tcoat (02-21-2018)
Old 02-21-2018, 11:11 AM   #3
cytogenesis
Can you provide some insight as to why you say Tein Flex over the STs? Also, should I get the Flex A or Flex Z?
Old 02-21-2018, 11:24 AM   #4
Are you looking for adjustability for some reason? Mostly just a street driven car? If not then you may be better off looking at simple lowering springs. There are some very good quality lowering springs out there at less than the cost of a cheap set of coil overs. If you stay around an inch then you do not need to start messing with LCAs and such.
Great choice on tires! I love them for a DD car.
Old 02-21-2018, 02:06 PM   #5
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Agreed on lowering springs being a better option for DD, but ST makes a fine coilover IMO. They're essentially KW V1s.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
wparsons (02-22-2018)
Old 02-21-2018, 05:31 PM   #6
mjanmohammad
There have been two members in our local 86 club that had ST coilovers that failed with little warning. They've since switched to other setups.
I've ridden in cars with Flex A, BC extreme low, Ohlins, etc. My favorite for DD has been the Flex A, on track has been Ohlins.
My car right now has OEM Sachs dampers, RCE Yellow springs, and Vorshlag camber plates.
As for Flex A vs Z, the Flex A have a hydraulic bump stop which make them significantly more comfortable than the Flex Z.
coilovers, spacers, suspension
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Small spacer vs big spacer Atomic Rooster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 11-09-2017 01:30 PM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
