Old 02-16-2018, 12:21 PM   #1
MRCA1ST
MRCA1ST's Avatar
Drives: 2013 WRB BRZ 6MT
Oil leak on front cam seal?
I was looking at the pics the shop took while my BRZ was getting repaired and I noticed that one of my cam-end-covers (?) is darker than the other three, looks like there is some oil leaking in that area. Has anyone else had issues in that arear? Or on one of the other ones?
MRCA1ST is offline   Reply With Quote
Old 02-16-2018, 01:08 PM   #2
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Pretty common issue. Had my car get fix under warranty. It has TSB for it for oil leak in few areas.
tintumz22 is offline   Reply With Quote
The Following 2 Users Say Thank You to tintumz22 For This Useful Post:
humfrz (02-16-2018), MRCA1ST (02-20-2018)
Old 02-16-2018, 01:35 PM   #3
humfrz
Yes, all too common place for an oil leak.
Why was your car in the shop .. ??
humfrz
Old 02-16-2018, 02:34 PM   #4
Yep.
Here is the TSB for the most common.
http://www.ft86club.com/forums/attac...1&d=1413834741
MRCA1ST (02-20-2018), tintumz22 (02-16-2018)
Old 02-20-2018, 08:04 AM   #5
MRCA1ST
MRCA1ST's Avatar
humfrz
http://www.ft86club.com/forums/showthread.php?t=124869
Yep.
Cool, thanks guys, I will check it out. I took a look at it and it seems pretty light, there is nothing on the under panel and nothing is actually wet.
The Following User Says Thank You to MRCA1ST For This Useful Post:
humfrz (02-20-2018)
Old 02-20-2018, 09:54 AM   #6
Ya I don't think I would even worry about trying to fix that. Just clean it up and see if it comes back.
humfrz (02-20-2018), MRCA1ST (02-20-2018)
Old 02-20-2018, 10:35 AM   #7
MRCA1ST
MRCA1ST's Avatar
I have a few months left on my warranty, so I think that is what I am going to do. If it comes back, I will have them deal with it.
Old 02-20-2018, 10:38 AM   #8
Oh ya for sure if still in warranty.
Old 02-20-2018, 11:21 AM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yeah, that's what I'm doing. Mine is leaking same place as OP as well as the passenger side cam cover I think. Cleaned it all up and paying more attention to oil consumption to figure out how bad it really is.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Tcoat (02-20-2018), tintumz22 (02-20-2018)
Old 02-20-2018, 11:44 AM   #10
humfrz
I don't thiiiiiiiiink so .......
humfrz
Old 02-20-2018, 12:13 PM   #11
MRCA1ST
MRCA1ST's Avatar
Mine is a late MY13, sold June 29, 2013 and only had 3k on it when I bought it in January 2016...so I still have some left
humfrz
it was there before all of that (grimy dirty buildup), I just hadn't noticed since it isn't dripping down on anything. And nothing got pushed back into the front of the engine, the engine sits so low in these things it stayed under the affected area. My Perrin tube did get cut by my top pulley/belt, but there's barely any clearance there to begin with.
humfrz (02-20-2018)
Old 02-20-2018, 12:20 PM   #12
humfrz
it was there before all of that (grimy dirty buildup), I just hadn't noticed since it isn't dripping down on anything. And nothing got pushed back into the front of the engine, the engine sit so low in these things it stayed under the affected area. My Perrin tube did get cut by my top pulley/belt, but there's barely any clearance there to begin with.
I was jest ah spoofing on ....... the body condition ....... about it "coming back", like in metal coming back to it's original position after being bent .....
humfrz
Old 02-20-2018, 12:27 PM   #13
humfrz
Place over the leak(s).
Tape into place.
Change once per month.
There ya go!
humfrz
finch1750 (02-20-2018), sato (11-07-2020)
Old 02-20-2018, 12:29 PM   #14
MRCA1ST
MRCA1ST's Avatar
Tape into place.
There ya go!
humfrz
Part Number?
The Following 2 Users Say Thank You to MRCA1ST For This Useful Post:
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Second time crank seal leak possible crank walk kiichiro Engine, Exhaust, Transmission 13 09-19-2018 05:57 AM
Auto FR-S - Oil Leak - Front Left of Engine iPlayDrums Issues | Warranty | Recalls / TSB 12 03-16-2018 11:48 PM
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-02-2015 11:51 PM
Oil leak problem, possible seal issue from repair? tintumz22 Issues | Warranty | Recalls / TSB 12 04-02-2015 12:56 PM
