Old 02-10-2018, 11:42 AM   #1
MassTroy
Subaru BRZ
MassTroy's Avatar
Drives: 2013 Subaru BRZ
Over filling oil to prevent oil starvation
I track my car and have had a history of rod bearing failure. I have been considering overfilling my oil level slightly to ensure that the oil pickup always has a good supply.
Does anyone do this?
How much do you overfill? Half a quart, quart, more?
Is there anything that would make this a bad idea? Im sure a lot of extra oil could be a problem. Ive also heard that if you fill it too high and the crankshaft is sloshing the surface of it that it can aerate the oil and cause it to act like very thin oil.
MassTroy is offline   Reply With Quote
Old 02-10-2018, 03:22 PM   #2
ls1ac
ls1ac's Avatar
Why do you think you are oil starved? These engines run at the track all the time with no problem.
If you are really worried an Accusump is the easiest and cheapest. Dry sump is the best and most complicated and expensive and works the best.
The Following User Says Thank You to ls1ac For This Useful Post:
humfrz (02-10-2018)
Old 02-10-2018, 03:32 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you running an oil cooler? What oil? Are you monitoring oil temp/pressure?
Old 02-10-2018, 05:24 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
From my experience only people that where paranoid about oil starvation, blew up their engine by doing all kinds of preventive measures.
As for me and my personal track times, I just made sure everything was toped off. Zero problems.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
humfrz (02-11-2018), Tokay444 (03-23-2018)
Old 02-10-2018, 07:19 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Aerating oil is bad. I've never heard of anybody over-filling to prevent problems.
http://www.ft86club.com/forums/showthread.php?p=3003331 talks about baffles.
Accusump is recommended.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Overdrive (04-12-2018)
Old 02-10-2018, 08:07 PM   #6
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
This thread might interest you: http://www.ft86club.com/forums/showthread.php?t=63723
TofuJoe is offline   Reply With Quote
Old 02-10-2018, 08:12 PM   #7
MassTroy
Subaru BRZ
MassTroy's Avatar
My rod bearing failed while doing a high speed run on the highway. My friend's engine had a rod bearing fail while on track. I just haven't wanted to spend the money on a sump yet. My friend just added baffles to his new engine.
I run the recommended 0w20 with an oil cooler now. I didn't have one at the time my car failed. My friend runs 5w30 and had an oil cooler when his failed. The data log of his temp showed totally fine in the 220-230 F range right up until about 30 seconds before the failure when it suddenly started rising. Probably already failing at that point.
The Following User Says Thank You to MassTroy For This Useful Post:
FastWhite (02-25-2018)
Old 02-11-2018, 11:32 AM   #8
Overfilling the oil can be as bad as having too little. If your concern is the oil moving enough that it can't be picked up then too much will move enough the get aerated.
ls1ac (02-11-2018)
Old 02-11-2018, 02:07 PM   #9
ls1ac
ls1ac's Avatar
A high speed run on the highway, hard to think of how starvation could happen. Many of us have run these cars very hard with no problems.
At a track, a very long carousel or turns are usually the problem. I would think that at the track your friend would be monitoring the pressure and temperature and seen the drop in pressure before the engine would fail. A pressure drop usually happens the same place in the same corner each time around. Staying in a higher gear will often help. Loosing a couple of tenths VS a DNF is a good plan.
This is coming from a guy that HAS left parts all over the track.
Again the first answer still holds. An Accusump might have helped your friend not sure what could have helped you on the street.
An other question-- were both of these problems in FRS or BRZ? Statement was not clear.
Old 02-11-2018, 06:17 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
He was only seeing 220-230?? Are you guys sure you have the sending unit in a good spot to read? With 5-30 I see 250 all day at the track with an oil cooler.
If you are that concerned that oil starvation is the issue racerx makes an oil pan that holds an extra quart and has baffles.
Old 02-11-2018, 07:36 PM   #11
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Where do you have your sending unit? Pics?
ApexEight is offline   Reply With Quote
The Following User Says Thank You to ApexEight For This Useful Post:
NoHaveMSG (02-11-2018)
Old 02-11-2018, 07:56 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
https://photos.google.com/photo/AF1Q...f4q_ep9-Dc5Cf4
Mine is next to the AC compressor.
Old 02-13-2018, 10:46 AM   #13
MassTroy
Subaru BRZ
MassTroy's Avatar
My high speed run was down a hill. I suspect the starvation happened at the bottom of the hill, but it seems weird.
Both cars are BRZs. Mine is a 2013, my friend's had a previously supercharged 2014 (we found this out after it failed).
Both of us use the OEM oil temp sensor read via OBDII. As far as I am aware, there isn't an OEM oil pressure sensor. I haven't invested in an aftermarket sensor yet.
Old 02-13-2018, 10:56 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The OEM pressure sensor is next to the OEM temp sensor.
oil, oil change, oil pressure
Fuel Starvation? Lunatic Tracking / Autocross / HPDE / Drifting 37 03-28-2018 11:47 PM
Filling out the low-end buzznasa Electronics | Audio | NAV | Infotainment 20 03-31-2014 01:21 AM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 11:19 AM
Oil starvation in high loads jdcorbitt3 Engine, Exhaust, Transmission 7 06-01-2013 10:46 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
