Old 02-07-2018, 05:20 PM   #1
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
supplementary oil pump
Hi Guys,
wondering if anyone has wired a secondary electric oil pump into the block?
reasons:
[1] supplement low oil pressure as needed, like at warm idle
[2] provide some oil pressure to block before cold start
[3] minimize oil starvation during steady state cornering (?)
I am thinking of a small electrical pump that provides 2 or 3 GPM of flow from the oil pan to the block. I would tap the oil pan (or use an aftermarket tapped one) with a line through an inline filter, then a check valve, to the pump, out to a galley connector on the block. Pump can be triggered manually via momentary switch or via low pressure oil switch at say 10psi.
This approach just moves the existing oil around better, it doesn't add oil to the system like an accusump (accumulator) might do at warm idle when trying to raise pressure.
one source for pumps:
https://www.rbracing-rsr.com/oilsystems.htm
Anyone done this or seen something similar?
thx
canyons
canyons is offline   Reply With Quote
The Following User Says Thank You to canyons For This Useful Post:
Williampreza (02-07-2018)
Old 02-07-2018, 06:35 PM   #2
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
Full Blown has an oil pan that would probably work for that. Where would you put the oil? That is, where in the block are you planning to put the output from this pump? Would you need a check valve in the block oil gallery to keep from stalling the oil upstream? or is this more of a spray-it-where-you-need-it thing? Interested in this idea.
Williampreza is offline   Reply With Quote
Old 02-08-2018, 12:30 AM   #3
canyons
canyons's Avatar
I was planning on going into one of the existing galley connectors, simpler is better. Probably the one at the front top of the block so the oil has to drain down back to the pan. Yes I was thinking of the Full Blown oil pan idea, extra quart of pan capacity ( makes it more likely there'll be oil in the pan for the pump! ) and an output port. Thanks!
Old 02-11-2018, 08:51 AM   #4
Williampreza
From the FA20 Engine Oiling, Bearings, and Starvation thread:
http://www.ft86club.com/forums/showp...8&postcount=72
Old 03-02-2018, 08:53 AM   #5
Williampreza
One of these might be more along the lines of what you would need:
https://www.atpower.com/oil-pump
oil pump
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 10:28 AM
WTB: FRS oem abs pump fcdrifter20 Want-To-Buy Requests 1 01-07-2016 08:28 PM
Pump recommendation jvincent Tracking / Autocross / HPDE / Drifting 9 09-15-2014 09:50 PM
Vac Pump sw20kosh Engine, Exhaust, Transmission 1 06-06-2013 08:46 PM
What gas do you pump? its_the_biz Scion FR-S / Toyota 86 GT86 General Forum 45 02-28-2013 12:22 AM
