Old 09-15-2014, 02:38 PM   #1
jvincent
jvincent's Avatar
Pump recommendation
Went to the track for the first time with the new tires yesterday and noticed that the valve stems on the new wheels are too short for head on the bicycle pump that I use.
It's a newer pump that supports both Presta and Shrader so it has to push on pretty far before it will depress the pin in the valve stem.
Anyone have a recommendation for a bike pump with an old school screw-on head?
Old 09-15-2014, 03:01 PM   #2
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
lossless valve - http://www.ebay.com/itm/Air-Shock-Pu...32f506&vxp=mtr
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 09-15-2014, 03:10 PM   #3
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Originally Posted by Danklvr View Post
I can only imagine the difficulty in pumping up a car tire with that thing.
I'd suggest an air tank. Cheaper than a good pump and a whole lot easier. Make sure the tires are close to what they need to be when you arrive at the track, use the tank to make small changes as needed.
celica73 is offline   Reply With Quote
Old 09-15-2014, 03:12 PM   #4
mla163
Overthinking it
Drives: BRZ in CS
I've had one like this for a good 8 years.
http://www.homedepot.com/p/Husky-12-...D12A/203356023
mla163 is offline   Reply With Quote
Old 09-15-2014, 03:14 PM   #5
Danklvr
Danklvr's Avatar
can not imagine why someone would want to use a bicycle pump for car tires, but.....
Old 09-15-2014, 03:15 PM   #6
TrqlessWonder
Drives: 2014 FR-S
This is the 12-volt pump I've been using for the last couple seasons. Adds about 8 psi per minute. I've been pleased with it so far.
http://www.aircompressorsdirect.com/...sor/p3207.html
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 09-15-2014, 03:49 PM   #7
jvincent
jvincent's Avatar
Thanks for the recommendations so far.
I bike pump isn't that bad since I'm usually only adding a couple of PSI on a tire. Usually takes three or four pumps.
Old 09-15-2014, 06:43 PM   #8
ddeflyer
Bicycle pumps are great for adding small, controlled amounts of air. When you are doing very small tweaks of air pressure the precision makes it easier to hit your target because there is less temperature change to the air in the tire.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 09-15-2014, 07:54 PM   #9
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
All kinds of reasons, really, but let me start with my go-to: Borrowers.
dradernh is offline   Reply With Quote
Old 09-15-2014, 08:50 PM   #10
Model Citizen
Lacking brains
Drives: frz
i bring an old quality standup bike pump, it works just fine, 40-50 pumps will add 10ish psi if need be
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Trackday GPS Recommendation milhouse Tracking / Autocross / HPDE / Drifting 12 03-24-2014 12:19 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
Pedal Recommendation? swift996 Tracking / Autocross / HPDE / Drifting 24 04-09-2013 07:57 PM
Recommendation for second modification? stratodyne BRZ First-Gen (2012+) — General Topics 29 03-01-2013 06:11 PM
PDX Recommendation for Detailing JayNutter Northwest 2 12-08-2012 10:26 PM
