Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Ice inside lower door weatherstrip
The last couple times I've attempted to open the drivers door over the last few weeks (sub freezing/near freezing weather), besides the window sticking to the weather strip, the lower seal on the door is stuck as well. I have to get in so I slowly pull the door open, cringing the whole time.
I just checked and both doors have ice inside the lower weatherstrips. I see there are holes along the length but they appear to be air holes as opposed to drain holes. I'm thinking of snipping some drain holes on the bottom edge of the strip to see if that alleviates the freezing issue. Thoughts? Anyone else seeing this? |
They are supposed to be drain hole. They work fine when the water is free flowing but the whole freeze thaw cycle can play havoc with the. Did you ever get the upgraded seals installed? I have not had any issue since I had it done.
Simply Forgotus
I wasn't aware of those lower seals being on a TSB, so to answer your question, no I have not had them upgraded. I suppose it's too late now, since I'm past my warranty period.
It is the upper seals that are on the TSB. They reduce the amount of water passing through the door quite a bit.
Simply Forgotus
So after about an hour drive, the ice inside the weatherstrip melted. I dried off the door jam and seal but when I close the door, water squirts out the "air" holes so everything gets nice and wet again, ready to refreeze.
I snipped a few holes on the bottom of the seal to allow the water to drain and dried everything off again...we'll see how that works out. Supposed to be in the mid 20's tonight. |
#6 | |
![]() humfrz |
| Loose nut rolling around inside door? | Mexibeetle | Issues | Warranty | Recalls / TSB | 36 | 01-18-2019 03:07 PM |
| WTB: Inside door grip cover or trunk mat. | Devante | Want-To-Buy Requests | 2 | 08-25-2017 10:47 PM |
| DIY - Door Weatherstrip Replacement | nemu-iii | DIY (Do-It-Yourself) Guides | 0 | 07-29-2017 03:15 AM |
| Weird: Can't unlock FR-S driver door from inside | pasternak | Issues | Warranty | Recalls / TSB | 5 | 09-17-2015 12:54 AM |
| Red inside door handle grips how to install? | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 03-24-2014 12:21 AM |
