Drives: Asphalt FR-S
Weird: Can't unlock FR-S driver door from inside
So I'm ready to exit the car and the unlock button on the driver door won't do anything. I'm sitting there pressing it over and over - nothing. Driver side door is locked and I'm getting hot. So I unlock using the button on the key and it works fine.
![]() This also happened once a year or so ago. 2013 FR-S - bone stock. |
Drives: 2013 Subaru BRZ Limited GBS
maybe a bad wire connection or bad switch on the door?
Drives: 2013 black gt86
hapenned a couple times when i had my keyfob and the phone on the same pocket.
magnetic field dont like more intense magnetic field |
hmmmm.........that just happened to me the other day.
I restarted the engine and it then let me out. It hasn't happened since then. Sometimes my right shoulder hurts for no reason ..... then it is OK ..... I just don't worry about things like that anymore..... ![]() humfrz |
#5 | |
not playing cards
hey you, yeah you <3
Drives: 2014 37J FR-S
take door apart, blow air to wires. Cross fingers.
| Loose nut rolling around inside door? | Mexibeetle | Issues | Warranty | Recalls / TSB | 36 | 01-18-2019 03:07 PM |
| Door Unlock Issue | TONYpepperon1 | Issues | Warranty | Recalls / TSB | 20 | 01-05-2018 07:06 PM |
| Door handle lock/unlock issue. | Skeneypoo | Electronics | Audio | NAV | Infotainment | 4 | 12-03-2014 04:55 PM |
| Red inside door handle grips how to install? | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 03-24-2014 12:21 AM |
| Automatic Door Lock/Unlock - Do we have the option? | RYU | Electronics | Audio | NAV | Infotainment | 17 | 10-04-2012 01:15 AM |
