Drives: 2017 BRZ
Rear sway bar bolts torque?
Can anyone tell me what the rear sway bar bolts are supposed to be torqued to? I'm planning to install a Driveway Labs diffuser in the next day or two hopefully, and I need to loosen/remove these bolts to do it and I can't find what they're supposed to be torqued to.
Drives: 2017 manual BRZ
Looks like 44 ft-lbs
http://www.ft86club.com/forums/showthread.php?t=85760 Sent from my Pixel XL using Tapatalk |
| The Following User Says Thank You to Somerandom18 For This Useful Post: | Brink (01-25-2018) |
#3 | |
Drives: Car
Drives: 2017 BRZ
These 2.
Chin Chief Instructor
Drives: 2015 Ford F150 Aluminium Couch
Stumbled across this thread and thought this might save others the hassle... see the picture attached of torque values for rear sway bar. The torque for the bolts on that bracket is 22 ft/lbs, not 44.
The guy in this video below likely looked at the first value listed... "30". That's not "ft/lbs", which I'm guessing it what he looked at, and he stripped the backing nut. See the legend at the bottom, the last number listed in parenthesis is the "ft/lbs" value.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap Building 1963 289 Cobra Le Mans Replica Cobra Replica Build Pics Chin Chief Instructor www.ChinTrackDays.com Last edited by jmimac351; 05-28-2018 at 07:42 PM. |
| Rear sway bar bracket bolts | Somerandom18 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-10-2017 10:03 AM |
| Driveshaft bolts torque | oliverc | Engine, Exhaust, Transmission | 1 | 11-06-2015 11:29 AM |
| torque specs for front and rear subframe bolts | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 06-17-2015 02:54 PM |
| WTB - OEM Sway Bar Reinforcement Plates and Stabilizer bar bolts | loading_please_wait | Want-To-Buy Requests | 0 | 06-16-2015 12:58 AM |
| FS: SPC Rear LCAs, SPC Camber Bolts, Eibach Sportline Springs & Sway Bars, Bilsteins | BRZZZZZZZZZZ | Canada Classifieds | 7 | 03-20-2014 12:16 AM |
