Old 01-22-2018, 11:53 AM   #1
redwine
Diff Oil is 1.15 L ?
Hello,
I am thinking to replace my Diff Gear oil.
The manual state 1.15L.
Does BRZ (2017) have 1 or 2 Diff Gear (front + Rear axle) ?
Need 1.15L or 2.3L ?
THanks
redwine is offline   Reply With Quote
Old 01-22-2018, 11:56 AM   #2
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Originally Posted by redwine View Post
Hello,
THanks
That 2.3L is for the Transmission. Unless you have the elusive AWD BRZ, then you wont have a front diff.
The 1.15L to 1.3L is correct for the diff.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following 3 Users Say Thank You to yelsew For This Useful Post:
Cole (01-22-2018), Summerwolf (01-22-2018), ThatAsianBradah (01-23-2018)
Old 01-22-2018, 12:27 PM   #3
redwine
Thanks for the confirmation ... yelsew
Gonna try out the Motul Gear 300 75W-9 finally
Also, thanks for moving the thread
Old 01-22-2018, 01:03 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Why?
(sry!)
As pointed out, BRZ is rwd, there is one diff, at the rear of the car...
Old 01-22-2018, 02:29 PM   #5
redwine
[QUOTE=ZDan;3031642]Why?
Hoping to get a better shift.
Look like quite a few are recommending the Motul.
Currently at 7000k.
Looking to replace the oil either at 10K svc or 20k svc.
Rgds
Old 01-22-2018, 02:33 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
[quote=redwine;3031721]
Originally Posted by ZDan View Post
Why?
Ah, in that case it is the transmission fluid you want to change, not the diff fluid (which doesn't affect shifting at all)
yelsew (01-22-2018)
Old 01-22-2018, 11:39 PM   #7
NRXRaptor
I replaced my gear oil last week with the meme motul gear 300 gear oil. I haven't noticed any difference in shifting at all. I changed the oil after ~17600 miles. I had already installed a shifter bushing, perrin transmission mount bushing inserts, mtec shift springs, and whiteline kits KTD 922, 925, and 926. Again, no difference with the new gear oil. Shift springs and shifter bushings made the largest difference in shift feel. It might be because my car is a 2016 model year, so maybe the cars came with better gear oil as time went on. I saw the image of the guy who replaced his gear oil at 1500 miles and mine was nothing like that. It was a waste of money for me unless oem gear oil costs the same
NRXRaptor is offline   Reply With Quote
Old 01-23-2018, 01:14 PM   #8
redwine
[quote=ZDan;3031732]
Good point ... Thanks !
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 01:07 AM
OEM Diff Kregar Mid-Atlantic 1 07-12-2016 05:30 PM
Diff oil HLHachiRoku Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 04-17-2016 07:12 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 03:59 PM
