Old 01-20-2018, 02:52 PM   #1
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Between Cusco and STI motor mounts...
Any input as to why one would lean towards one as opposed to the other. Cusco is slightly less expensive but is supposed to generate more vibrations. The poly seems more robust than the STI mounts, though.
STI is obviously subaru approved and should be slightly better to live with day to day. The vibration issue isn't a huge deal, honestly.... just looking for other's input.
Thanks!
Old 01-20-2018, 02:56 PM   #2
gtengr
Drives: 2017 BRZ
I have the sti engine and trans mounts and they are stiffer than what I usually think of when it comes to rubber bushings. Great upgrade, and I wouldn't want anymore stiffness than what they provide. That they use OE-quality manufacturing is icing on the cake.
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
kevaughan (03-09-2024), Pat (01-20-2018)
Old 01-20-2018, 03:06 PM   #3
humfrz
Thanks!
What's wrong with the mounts that are in your car ....... did the massive torque load pull one of them apart .... ??
- humfrz ...... go take a nap.
Old 01-20-2018, 04:23 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Doing overpipe and frontpipe soon with an SC to follow. Just preparing.
The Following User Says Thank You to Summerwolf For This Useful Post:
humfrz (01-20-2018)
Old 01-20-2018, 04:23 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
You'll notice the change with the STi mounts when you want to... Not idling at a light when the SO says "your car is running really rough".
My midpipe was hitting the rear subframe under acceleration stock, not with STi.
Old 01-20-2018, 10:00 PM   #6
ryoma
ryoma's Avatar
I got the Cusco one cause it was cheaper. I don't really notice it at all anymore.
Old 01-22-2018, 07:45 AM   #7
Fred E
Drives: WRB BRZ
Cusco mounts were recently put on after 95k miles on the OEM mounts. My engine moved so much on the OEM mounts causing my turbo kit's downpipe to knock against the frame. Absolutely no touching or movement at all with the Cusco mounts. There's a considerable increase in vibrations when taking off (but doesn't bother me at all), a minor increase at idle, and i can't tell a difference at all while cruising.
Fred E is offline   Reply With Quote
The Following 3 Users Say Thank You to Fred E For This Useful Post:
Bonburner (06-28-2020), kevaughan (03-09-2024), Summerwolf (01-22-2018)
Old 01-22-2018, 08:13 AM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
I am slowly leaning towards the cusco mounts. I also have their transmission collar....so... why not, lol.
Old 01-22-2018, 08:55 AM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
The STi mounts are nicer for a car that is daily driven, and worth retaining a bit of comfort in my opinion.
I've found through the years that if you touch more components less you can often get a 'package' that is greater than the sum of it's parts.
A lot of people do solid motor mounts with stock trans mounts, and end up with tons of vibration and say there's no way they'd want to add more by doing the trans mounts. If they do STi motor mounts, and a whiteline trans mount insert, or a similar setup it's often more livable, and 99% as performance oriented.
Just my opinion, there's no wrong way to do it, just different ways.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following 4 Users Say Thank You to JazzleSAURUS For This Useful Post:
Barefootdan (01-22-2018), gtengr (01-24-2018), kevaughan (03-09-2024), Plumbus (09-05-2020)
Old 01-22-2018, 09:23 AM   #10
rns294
Drives: 13 BRZ
What about the Perrin mounts? Anyone used those?
rns294 is offline   Reply With Quote
Old 01-22-2018, 09:55 AM   #11
Summerwolf
Panda Trueno
Summerwolf's Avatar
http://www.ft86club.com/forums/showthread.php?p=1552772
I am sure this is not a common occurrence, but there is my reasoning not to go Perrin.
Fred E (01-22-2018)
Old 01-22-2018, 01:05 PM   #12
Amputechture
Drives: 2014 BRZ
I use the STI mounts, perhaps my stockers were going to hell, because I actually find that the car is quieter with them. They are fine and work well, it's not a night and day difference but you feel a noticeable difference in throttle response and an overall 'tighter' feeling all around. I'm happy with them.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 01-22-2018, 01:32 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The difference between the two is that the STI was designed with a street car in mind, so there's a lot less NVH (especially at odd RPMs).
If you want to minimize random rattles from inside your car as you drive, go with STI. If you don't care, go with Cusco.
The Following User Says Thank You to mav1178 For This Useful Post:
Pat (05-23-2018)
Old 01-22-2018, 02:09 PM   #14
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Just installed Cusco mounts a couple weeks ago prior to installing the turbo. The only negative aspect, in my opinion, is a bit of vibration while taking off from a stop but I fully expected that to happen. The biggest improvement was that it really took up a lot of slack in the driveline and made a big difference in on/off throttle response. Well worth the upgrade, imo.
Jesse36m3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse36m3 For This Useful Post:
Bonburner (06-28-2020), Fred E (01-22-2018)
FS: Cusco Motor Mounts bombardius Engine, Exhaust, Bolt-Ons 2 10-01-2018 06:04 PM
WTB: Cusco Motor Mounts SterlingBrz Want-To-Buy Requests 1 09-04-2014 12:44 PM
WTB: Cusco Motor Mounts SterlingBrz Want-To-Buy Requests 0 09-04-2014 12:15 PM
WTB: Cusco Motor Mounts ASAP srt4_night_rider Want-To-Buy Requests 8 08-17-2014 05:57 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
