Old 01-18-2018, 09:05 AM   #1
cheeseburger
IG: @_southwell_86
cheeseburger's Avatar
Drives: Rwd Prius.
The maxx seat time / drift build.
I spent the past season (2017) learning how to drift / learning the car and learning what to change accordingly. As it sits now the set up is great for a low power RELIABLE drift car. An emphasis on suspension set up. The stock cars stay out on the track the longest
Engine:
Apexi drop in
Cusco intake tube
Tomei uel header
Tomei overpipe
Motive mid pipe
Mxp cat back
Cusco engine mnts
Redline fluids engine/trans/diff
Magnetic drain plugs engine/trans/diff
Suspension:
Fortune auto 500 coilovers w/. 8k/8k swift springs
Parts shop maxx front angle kit
Buddyclub lca
Voodoo rear toe arm
Brakes:
Stoptech rotors
Hawk hp+ pads
Oem pads (hydro)
Goodridge ss braided brake lines
Asd hydro hand brake
Dayton one duel caliper bracket
Second set of oem brz calipers
[ame]https://m.youtube.com/watch?v=NPVSnSwR2Aw[/ame]
[ame]https://m.youtube.com/watch?v=nL2MTAcr_UU[/ame]
Tons of plans for the future
cheeseburger is offline   Reply With Quote
Old 01-18-2018, 09:37 AM   #2
Teseo
Drives: frs
No oil cooler?
Old 01-18-2018, 09:55 AM   #3
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
Originally Posted by Teseo View Post
No oil cooler?
Oil cooler and radiator upgrades are happening this winter
Old 01-18-2018, 01:30 PM   #4
TheMuffinMan
Slowpoke
TheMuffinMan's Avatar
Drives: FR-S Whiteout MT
Nice build! I was looking to run those Corbeau seats too, but haven't seen much info about them on this forum. Do they fit in the car well? What mounting hardware did you use? I also like the old school fender flares.
TheMuffinMan is offline   Reply With Quote
Old 01-18-2018, 02:25 PM   #5
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
They’re the fx1 pro’s. They fit well and are currently using corbeau bottom mount duel lock sliders. Thanks. The fender flares are just cheap Ebay ones to cover the added track width.
Old 08-08-2018, 01:00 AM   #6
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
Updates. Lots of stuff. But I’ll just ad some pictures
Preparing for the cage
Pbm weld in rear diff bushing
—Refreshed the rear subframe—
Pbm solid subframe bushings
Pbm sold diff bushings
Lexus is300 3.909 diff (welded)
Voodoo trailing arms
Voodoo toe arm
Buddyclub lca
Energy a-arm and knuckle poly bushings
Before
After
2013 frs
I 🖤 drifting.
https://youtu.be/XW5XBQuLDUM
IG: @_southwell_86
Old 08-25-2018, 10:51 AM   #7
timandytimandy
Wanna-be
timandytimandy's Avatar
Drives: 2013 Firestorm FR-S
Man, I really need to get to Englishtown. How do you like the 3.9?
timandytimandy is offline   Reply With Quote
Old 11-04-2018, 08:31 AM   #8
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
After a few weeks the difference is hardly noticeable. But aver all its ok.
2013 frs
I 🖤 drifting.
IG: @_southwell_86
Old 12-25-2018, 06:18 AM   #9
Pschultz91
Drives: 2013 Frs
Engine:
Apexi drop in
Cusco intake tube
Tomei uel header
Tomei overpipe
Motive mid pipe
Mxp cat back
Cusco engine mnts
Suspension:
Buddyclub lca
Voodoo rear toe arm
Brakes:
Stoptech rotors
Hawk hp+ pads
Oem pads (hydro)
How do you like the Dayton bracket? Do the oem calipers have enough bite to lick up the rear wheels? Also where did you order your brake lines?
Pschultz91 is offline   Reply With Quote
Old 01-18-2019, 11:22 AM   #10
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
The Dayton bracket is great. Stock calipers and pads are perfect and I got the lines from a local speed shop
2013 frs
I 🖤 drifting.
IG: @_southwell_86
Old 01-18-2019, 06:33 PM   #11
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
LOVE what you've done to the car! Makes for a perfect weekend toy!
eastendraceshop is offline   Reply With Quote
FR-S Drift Build BuhhDill Member's Car Journals 37 01-19-2015 03:40 PM
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
BRZ drift build. now with more JZ epson1 Member's Car Journals 12 09-21-2013 09:34 AM
FT86c Drift & Time Attack Races in GT5 ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 153 06-25-2011 05:53 PM
