Old 01-16-2018, 06:44 PM   #1
hpde_addict
Drives: '18 Camaro V6 1LE
Would it be worth it to replace clutch at 40k miles?
I'm having my transmission replaced as part of a warranty claim. The dealer offered to replace the clutch assembly with no labor cost for $900 + tax. Would it be worth it to have them change it?
My clutch pedal has a squeak sound and some resistance at the last 1/3 of travel, especially in the cold or on the first start of the day. It's been like this for the last couple of years. Lately, I also hear some rotating squeak when I'm engaging the clutch pedal in the morning.
Looking online, it seems that the part a lot of people have a problem with is the throw out bearing, not the clutch. It looks like Subaru has come out with a new design for the throw out bearing as of 2017. Would it make sense to just replace the throw out bearing, instead of the entire assembly? The labor cost would be minimal due to them already taking the transmission out. Looks like 0.2 hours of labor from their book: http://www.ft86club.com/forums/showp...3&postcount=65
hpde_addict is offline   Reply With Quote
Old 01-16-2018, 07:27 PM   #2
D-rek07
$900 is too much for a clutch/pressure plate. The stock clutch should last much longer than 40k miles. I would replace the throw out bearing but not the clutch.
D-rek07 is offline   Reply With Quote
Old 01-16-2018, 07:34 PM   #3
humfrz
Yep, I agree to replace the TOB.
If you have been the only owner of the car and hadn't abused the clutch, I'd leave it alone unless it looks abused.
Make sure they lub up the clutch fork.
humfrz
Old 01-16-2018, 07:42 PM   #4
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I had a Suzuki SX4, bought it with like 32k miles on the clock. Sold it @ 122k miles and now it has about 150k miles with the stock clutch still intact.
Trueweltall is offline   Reply With Quote
Old 01-16-2018, 07:52 PM   #5
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Ouch. That's way too expensive. Clutch kit should be about $220-250. So if you want a new clutch kit get it yourself and give it to the dealer to install. I agree, get that TOB replaced anytime the trans comes out.
Once your out of warranty I would go to Neal @ theracersline in concord he does great work at good prices.
DandoX is offline   Reply With Quote
Old 01-16-2018, 11:29 PM   #6
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I got my clutch, flywheel, TOB, transmission fluid replaced for $900 all together including labor
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 01-17-2018, 11:42 AM   #7
RallySTI
Drives: 2013 Subaru BRZ
If you are replacing the throw out bearing make sure to get the updated version.
30502-AA150 is the updated bearing part number from Subaru.
I have heard the Toyota part is cheaper but I have not checked for myself.
RallySTI is offline   Reply With Quote
Best independent mechanic to replace clutch? Barre Northern California 2 09-15-2017 02:57 PM
Replace Clutch or Time to Upgrade? Antialias Issues | Warranty | Recalls / TSB 9 11-19-2016 08:44 PM
Low mileage and going FI - Replace clutch or wait? FirestormFlex Forced Induction 8 12-16-2015 11:44 PM
Worth it to replace or just keep it as is? x1UP BRZ First-Gen (2012+) — General Topics 15 12-04-2014 03:58 PM
OEM Clutch Replace time JRollar Engine, Exhaust, Transmission 18 06-19-2013 12:25 AM
