Old 12-13-2015, 07:22 PM   #1
FirestormFlex
Drives: 2015 Turbo FR-S
Low mileage and going FI - Replace clutch or wait?
Am in the process of gathering supporting mods for my turbo build. I'll be running the SBD kit at 10psi. My question is this - my car is a 2015 with 10,000 miles on it. Most of my driving is on the highway. Do I update to an Exedy Stage 2 clutch now or wait?
FirestormFlex is offline   Reply With Quote
Old 12-13-2015, 07:38 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
There is nothing worse than a slipping clutch while your car is on the dyno being tuned.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
funwheeldrive (12-13-2015)
Old 12-13-2015, 07:41 PM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
What he/she said ^^
Upgrade it
Freeman is offline   Reply With Quote
Old 12-13-2015, 07:46 PM   #4
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Make sure you go higher weight oil. Pro tip.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 12-13-2015, 09:35 PM   #5
scarfo
Drives: gts 86
im running the exedy stage 1, on 300hp at 14psi, approx 255wtq with 0 slip( i make full boost at 3500rpm) , dont think the sbd kit can produce much more than that. The stage 1 feels very close to the stock clutch.
If your aiming around the same figures id look into it, as i get stuck in traffic alot and the heavier duty clutch's in stop start make you want to punch the dashboard
scarfo is offline   Reply With Quote
Old 12-14-2015, 02:09 AM   #6
FRS Justin
Drives: 2013 Asphalt FRS
I would wait. You never know it might last you a long time. If it does go out its only a 2 to 3 hour job to replace.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-14-2015, 03:50 AM   #7
Northwest86
Drives: Velocity Orange 86 GT
The stock clutch was in my case taxed on the stock car with AD08r's. Let alone when I added boost. Something like the Clutch Industries clutch which is similar in feel is excellent for lower boost settings. I will always say this. Do it once, Do it properly.
Northwest86 is offline   Reply With Quote
Old 12-14-2015, 01:48 PM   #8
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I vote before, that way you can make sure everything is happy prior to adding boost. One less thing to troubleshoot. Will also allow you to break in the new clutch incase your car doesn't run too hot before it is fully tuned. No worries of glazing a fresh clutch on the dyno that way.
Old 12-16-2015, 11:44 PM   #9
mrk1
Drives: Sterling BRZ Ltd
Do it before, get through the break in so you don't have to think about it when you want to go have fun with your new turbo. Then again that turbo isn't big power so if you don't hammer your car the stocker could last a good while.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
SOLD! OEM Exedy clutch, low mileage, great shape. $45 shipped. boostedbrz Engine, Exhaust, Bolt-Ons 21 05-17-2015 04:10 AM
Replace entire OEM clutch assembly, or disc? radroach Engine, Exhaust, Transmission 8 08-07-2014 11:00 PM
Dealership is charging me $1725 to replace my OEM clutch for BR-Z venom8776 BRZ First-Gen (2012+) — General Topics 147 02-02-2014 08:34 AM
FOR SALE: Stock Clutch / Flywheel / Pressure Plate (Ultra Low Mileage) Synack Transmission and Driveline 7 11-01-2013 11:19 AM
OEM Clutch Replace time JRollar Engine, Exhaust, Transmission 18 06-19-2013 12:25 AM
