| CANADA Canada |
Drives: 2013 Scion FR-S Asphalt [Gray]
Mega Ultra Cold Engine Stuff Questions
In extra, extra cold weather, SHould your engine oil start to cool down while still on and hot at idle?
Scenario: I drive to work in the morning... Engine gets to about 80% OP-TEMP, I park, have a smoke and leave the car on cuz... it's cold af. Should my Oil temp stay, keep climbing to perfect operating temp or start to dip slowly which is what mine does. Hope my thermostat is not broken but that's the first thing that comes to mind unless it's normal in extra cold weather. Thanks, |
BRZZZZZ
Drives: 2013 BRZ Whiteout
With the weather that we have been getting up here recently, I won't be surprised if the oil temps doesn't keep climbing to optimum temps during idling.
I have noticed that once I start the car in the morning these days, no matter how long I wait, the oil temp won't get the perfect temp until I start driving it. Same goes for the coolant temps. |
#3 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Idling means no load. No load means, engine doesn't churn out much horsepower which means not as much heat generated.
With the extreme temps we are getting, that could very well mean no load situations might not replenish the heat that's being dissipated to atmosphere which could mean temp could actually never hit optimum in an idle situation.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#5 | |
Rice King
The best way to warm up the car is to drive it. Idling I find is next to useless beyond just getting the fluids running in the car for correct and smooth operation. These aren't considered extreme temps though unfortunately, well, if you are close to the large cities, toronto, markham, scarborough, pickering, etc. Up north in muskoka, the temp dropped to -37. The toilet bowl was ice cold and the water inside it was literally frozen, inside a heated/insulated cottage.... -20 is weak compared to that shit up north lol.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#6 | |
Rice King
Really? I can't imagine the difference in temp being that great from scarborough to pickering? Do you know what day this was, I'm interested to see if it was actually that low
Glorious Honda.
Not a troll
Coldest it's been in Scarborough in the past month is -24 according to The Weather Network. Though, measured at Buttonville, so not exactly super accurate.
#9 | |
Rice King
Lowest temp was -22 in Toronto area, couldn't search Scarborough precisely. Lowest temp in muskoka lol, -36. Never again do I want to be out in that crap, snow squalls were horrific driving conditions if you got stuck in it. https://www.timeanddate.com/weather/...h=12&year=2017 https://www.timeanddate.com/weather/...h=12&year=2017
Glorious Honda.
#10 | ||
Although windchill does not impact inanimate objects (it is the temperature that the human body feels as to what it actually is) it would indeed remove the heat from a car block while you are moving marginally faster than if sitting still.
#11 | |
Rice King
Glorious Honda.
#12 | |
#13 |
Well you did well since you were damned close.
#14 | |
Keep in mind this was an old Lexus LS and not the BRZ. Maybe sensor is off. Edit: Using the same website you used, it shows -21 C. Bad readout I guess? Not sure how the 2nd gen LS picked up outdoor air temps.
| FS: Pennzoil Ultra 0w-20 Synthetic Engine Oil | zc06_kisstherain | NY / NJ / CT / PA | 0 | 05-23-2016 10:45 AM |
| Do e85 cold starts damage engine? | jaorocks1 | Engine, Exhaust, Transmission | 20 | 12-02-2015 05:12 AM |
| Weird stuff in engine | dazbrz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 11-03-2015 04:12 PM |
| whistling sound from engine bay when cold | smbstyle | Issues | Warranty | Recalls / TSB | 3 | 01-09-2015 12:03 PM |
| Engine stumble around 2.5k rpm in cold weather | Eyesacky | Issues | Warranty | Recalls / TSB | 2 | 11-02-2013 04:50 PM |
