Old 12-29-2017, 07:03 PM   #1
amanzoli
amanzoli's Avatar
Drives: 2015 Subaru BRZ series.blue
Does anyone know where the Fuel Relay Switch is located?
I am trying to locate the Fuel Relay Switch in the 2015 BRZ, Can someone please explain where it is. Also does anyone have a picture of it or can they take a picture of it.
amanzoli is offline   Reply With Quote
Old 12-29-2017, 07:06 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by amanzoli View Post
I am trying to locate the Fuel Relay Switch in the 2015 BRZ, Can someone please explain where it is. Also does anyone have a picture of it or can they take a picture of it. I need to pump the gas out of my tank and from videos I have seen on you tube of people bypassing the relay switch, this is the most efficient way to do it. Any help would be appreciated.
I'm pretty sure the pump driver is on the right side behind the door. I don't think it's controlled with a simple relay but don't take my word for it. Link to manuals are in my sig.
Old 12-29-2017, 07:26 PM   #3
amanzoli
amanzoli's Avatar
I am looking for the relay that I can use a paper clip to switch into the open position so it continuously pumps the gas. Rather then it just priming. I know this is a way to do it, but to sit and press my start button until 11 gallons is gone will take forever.
Old 12-29-2017, 08:16 PM   #4
Ultramaroon
not playing cards
You can run it with techstream. I don't know if it has a duty cycle but it's not designed to run all the time. It's designed to maintain pressure in a closed system.
Old 12-29-2017, 08:17 PM   #5
amanzoli
amanzoli's Avatar
What is that and how does it work?
Old 12-29-2017, 08:27 PM   #6
Ultramaroon
not playing cards
Toyota diagnostic software and a j2534 passthrough device. It runs from a windows computer and plugs into the obdii port.
Old 12-29-2017, 10:48 PM   #7
navanodd
Drives: 2013 BRZ Sport-tech WRB
I agree. Wouldn't recommend running this constant to drain all 11 gallons. If you can get it going, it should be intermittently to allow the pump to cool down. Otherwise there is a good change you will overheat and burn out the fuel pump.
navanodd is offline   Reply With Quote
Old 12-30-2017, 02:20 AM   #8
amanzoli
amanzoli's Avatar
When you are driving doesn't the fuel pump run constantly? Or is it only to prime the fuel lines? I'm a bit confused. I thought as long as fluid was running through the pump it would not burn out.
Old 12-30-2017, 10:43 AM   #9
Grady
Grady's Avatar
Yes this pump is a 100% duty cycle pump. However when you run out of gas and it starts to cavitate it will loose lubrication and overheat quickly.
Old 12-30-2017, 11:21 AM   #10
navanodd
I'm going on the assumption here that this is a small centrifugal pump. Even if it is turned on, with the small amount of flow for normal driving the pump will not be drawing much power.
Locking this pump at full output with no restriction on the fuel line is asking the pump to do more work than usual. It is possible that it is designed with this in mind. The more current the pump is drawing, the more things are heating up. This type of pump usually doesn't like to run without any back pressure.
If these are positive displacement pumps, then go right ahead and only get concerned about heat when the tank is near empty. Backpressure won't matter either. A positive displacement pump will always flow the same amount, so it would have a kickback to dump fuel back to the fuel tank when it is pumping more fuel than the engine needs.
Anyone know what typical construction of a fuel pump is?
Old 12-30-2017, 09:39 PM   #11
amanzoli
amanzoli's Avatar
I decided to pull the fuel pump assembly out and use a battery operated transfer pump to siphon the gas out.
draining gas tank, fuel circuit, fuel pump, fuel relay
is main relay kill switch bad for ecu? Packofcrows Electronics | Audio | NAV | Infotainment 3 07-18-2015 01:55 AM
FRS Fuel Kill Switch? nabil_frs Electronics | Audio | NAV | Infotainment 5 07-09-2015 08:45 PM
Making the switch to Ethanol, Flex Fuel Video Inside.... spdbydesign Forced Induction 0 05-23-2014 11:07 PM
Fuel or Battery Kill Switch? nabil_frs CANADA 3 03-09-2014 08:43 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
