Old 12-27-2017, 02:17 PM   #1
Scir16v
Drives: 240sx, 2013 frs
Scir16v's flood car
Hey guys. I had an FRS prior to this one, but had to sell to finance a garage.
I bought this car at Copart auto auction in November. One of those flood cars from Houston.
This is of course trailering it home.
I got this one as it seemed the most promising. The wheels are gram lights 57DR sized @ 18x9.5 +38. Wrapped in Hankook Ventus v12 that are 245/35/18
It has spec-d tuning headlights, which will be getting an HID upgrade in the future. It also has spec-d tailights. and some random led corner markers.
Moving to exhaust, quite surprised to find a Berk muffler delete.
Suspending the car is a set of Tein Flex Z coilovers
As far as stock options, it does have the first gen Bespoke headunit.
I have done some work on the car. I found that it had water oin one of the cylinders. I removed the exhaust manifold and also went through the process of changing the plugs as it has 74k on the clock.
After getting the water out of the cylinders and draining the oil. Putting in fresh oil with a few more detergents(aka Diesel engine oil) I tried to turn it over.
Unfortunately, it punched a hole in the block. Back cylinder, passenger side.
Now that I know there was potential for having a bad motor with any water being in it. It knocked during it trying to startup. I tried to prime it before any startup, but I think it was a goner before then.
So the next thing is to swap the motor out. I have a lead on a 40k mile motor locally and will be getting that after the first of the year.
Updates then
Scir16v is offline   Reply With Quote
The Following 2 Users Say Thank You to Scir16v For This Useful Post:
Cole (01-12-2018), Vin (12-27-2017)
Old 12-27-2017, 02:22 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Good luck on the build, will be a fun project. Mind telling how much money you have in it so far?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 12-27-2017, 03:02 PM   #3
Scir16v
With getting it back home, auction, fees, taxes, and gas. About 6k currently. All said and done, I'll be at about 8500
Old 12-27-2017, 03:27 PM   #4
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
2JZ?
TheBRZsKnees is offline   Reply With Quote
Old 12-27-2017, 07:36 PM   #5
Scir16v
Just a stock swap for now. I need to get it registered as a prior salvage car
Eventually I'll do some sort of motor swap to it.
Old 12-27-2017, 08:35 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Old 01-12-2018, 01:09 PM   #7
Scir16v
Alright guys. So, I picked up a motor that has 65,xxx on it.
First couple of questions.
I know that the suburu threebond doesn't seem to be a great sealant.
Has anybody resealed the timing chain cover with ultra grey RTV? I've had good luck in the past on SR motors.
Where can I find lifting hooks fir these motors? I get that I could just lift from the intake, but plastic, ugh.
Old 01-12-2018, 04:58 PM   #8
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I'm interested to see pics of what condition the rest of the car is in! Is/was the interior caked with mud??
JeremyR is offline   Reply With Quote
Old 01-12-2018, 05:13 PM   #9
Scir16v
Here's the pictures of the interior that came from the auction website that I had to go off of.
Old 07-26-2018, 10:36 AM   #10
Scir16v
After pushing the FRS to the back burner for winter and working on the getting the new garage floor ready for use, I was able to get this thing into said garage.
I have bought some other parts for the motor change. I got a fidanza flywheel and an exedy oem clutch. Versus clutch fork and pivot, along with arp flywheel bolts.
Pulling the engine next week.
The Following User Says Thank You to Scir16v For This Useful Post:
JeremyR (08-06-2018)
Old 07-26-2018, 11:25 AM   #11
ermax
ermax's Avatar
When I rebuilt my engine I stuck with the TB1217H. Who knows what the longevity will be though. The 1217H comes in a tube that fits in a calk gun which was really nice. In the past I always done Permatex in the normal toothpaste like tubes and they are a pain in the ass to use because your hands get all cramped up. If you go with Permatex go for the caulk gun tube.
As for lift points, there is already a hook on the back of the engine. What I did for the front was unbolt the AC and then reuse one of the AC bolts as a hook. I wrapped the bolt in duct tape so the threads didn't get damaged and also made sure I screwed it in as far as possible giving just enough to get my hook on it but no more.
Pulling this engine is super easy. Putting it back in went smooth too.
The only other thing I can think to point out is the fuel lines need a special tool to disconnect them. I found a video of some guy using zip ties to release the lines. Search YouTube and you will find it. I cut the ends of the zip ties off so they weren't pointed anymore. Then you look closely at the inside of the release and you will see the tabs. Jam the zip ties into those tabs (they are 180deg apart) and it will release.
The Following User Says Thank You to ermax For This Useful Post:
Scir16v (07-26-2018)
Old 08-06-2018, 03:11 PM   #12
Scir16v
Motor pulled. Was really easy to pull.
The replacement fa20, I pulled the timing chain cover and resealed. 32 bolts, ugh.
Old 09-14-2018, 10:21 PM   #13
Scir16v
So I got it all back together and ran into a wall.
The car runs great, everything works, drives like a dream. Titling issues are causing me to determine what to do next.
Had no idea that there is a branding of car title that doesn't allow you to rebuild the car for road use.
Still trying to figure out if there is some sort of loophole to get around it, but not sure.
So, it may be for sale soon as a off-road use only car (I.E. Racecar) or a complete part out.
Stay tuned for details
Old 09-14-2018, 10:41 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
WTF did I just read? I thought you put it together stock. Is this a Missouri thing?
FR-S Flood Car|| Help get running. Ryan Tuerck Issues | Warranty | Recalls / TSB 14 04-28-2014 02:53 PM
Flash Flood Water Damage - Please Help Mollusk Scion FR-S / Toyota 86 GT86 General Forum 27 09-16-2013 04:28 PM
Toronto Flood July 8th 2013 nos145 Issues | Warranty | Recalls / TSB 2 07-10-2013 11:47 AM
Fuji 86 Style 2012 JDM @ Fuji Speedway (Photo Flood) shawrf1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 59 08-19-2012 11:13 PM
